Curious to know what people's thoughts are on this fuel pump. 350 lph is closer to what I'm looking for and it comes with integral check valve. Also has a 6mm hose barb to run the venturi to pump the other half of the tank. There's also a 500 lph variant that draws less than 15 amps which is pretty impressive IMO.
745276444_ScreenShot2022-12-07at10_19_27PM.thumb.png.b15311c9f2ccd73e5acb6b566cb9d753.png
https://www.sau.com.au/forums/topic/484262-fuelab-49604/
26 minutes ago, joshuaho96 said:
Upgrade to the 49614? I strongly doubt I'll ever need to though. 300 kW to the wheels at best is what I'm trying to engineer the whole system around.
My brain won't let me accept that lol.
My gtst makes about 350kw and I feel like the car is only starting to wake up now. If I had a GTR, I would need substantially more power then that.
Do you have any plans to track the car?
https://www.sau.com.au/forums/topic/484262-fuelab-49604/#findComment-7973335
I want the car to survive extended track use but it's not the intended use, this is mostly just for fun on the street.
https://www.sau.com.au/forums/topic/484262-fuelab-49604/#findComment-7973340
Well, I guess if you get this pump, you'll end up with a working pump that suits your needs.
I know your going to enjoy the extra work required to get it running the way you would like it too, so I suppose the only downside is cost?
https://www.sau.com.au/forums/topic/484262-fuelab-49604/#findComment-7973344
Yeah I was hoping to learn more about the finer points of trying to make this pump fit some kind of R33 fuel pump hanger. Does the 6mm aux jet need to be used? Are the inlet/outlet vaguely in the right place? Stuff like that.
https://www.sau.com.au/forums/topic/484262-fuelab-49604/#findComment-7973345
Ah, got ya.
Mounting will be very easy. It is physically smaller then the typical fuel pumps used these days.
For the average bear, they probably wouldn't care about the aux jet. You might be interested in it though.
High power pumps can overpower the stock venturi which is designed for the lower flowing stock pump.
From my experience using the stock venturi, I've run my tank down to 5 litres remaining 3 times now. Once the car was barely running (would stall under any amount of G forces), once the car was 100% perfect (didn't even realise there was only 5 litres remaining at the time), the other time the car died and was unable to be restarted.
I account this to my stock venturi being inconsistent with the high flow pump.
If the stock venturi is happy to work with what that aux jet is supplying, you would resolve these issues of inconsistency.
But yeah, for the average bear, I don't think they would care about this until it caused a bigger issue (which it does once you go to 2 or 3 pumps, but they resolve the issue by having a correctly sized venturi in the hat).
https://www.sau.com.au/forums/topic/484262-fuelab-49604/#findComment-7973352
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
    • Yeah I also looked at Plazmaman, but, it ended up alot  cheaper getting black ones through EFI when you also added in the delivery cost
