it's a problem that all girls face when they have a modified car. Most guys assume that it's her boyfriends car. Just ask MISGSR :)
Girls don't get much respect when it comes to their cars and this needs to change.
If I see a chick out on the road in a nice car, I'm like "Respect!!!"
  • Replies 56
Originally posted by MIZ.33T
d more i thik abt this .. d more the idea appeals to me....ALL CHICKS dat feels d same and drives a fast car... please... lets gang together and fight this STIGMA     :burnout: :burnout: :burnout:
so guyzz... a little plea..'give us girlz a fair go!' [/b]
hhehe...u live in a man's world MIZ.33T...so u'll have to live with the misunderstanding =) but u have my utmost respect!!! hell u were into cars way before me!!!
just a little advice - take pikachu off the dashboard!!!! lol :)
blue s15 200sx, i always see ya when im out west around canley vale.
yeh runs suck these days, aint seen anything good happening lately, its turning into more of a cruise around the west, meet up at the new orange grove maccas and chill out thing.
At least the new maccas car park is huuuuuuuuge :)
Originally posted by XrSiSt
The only girl i knew with a line was Shell. Think u've started
something here! aehaehae
haha i remember back to the old SDU days when there was just me and Jen ...we were so outnumbered...this is great! more gals! yaayyyy! we'll be able to have a CHICKS ONLY skyline cruise ..just watch out we'll be taking over soon mwaahahaha *evil laugh* :) :) :)
Originally posted by HUSTLR
Call me RU3L8R lol:lol: :lol:
thats what i'm known as now lol
Hahahaha....yeah i remember your car from the gong cruise on sunday! Interesting number plate.... ;)
My girls a series 2....and silver is a great colour!!! :) Though you are right...there are way to many silver ones out there...i never noticed till i actually got my own!!!
MISGSR- i thought a guy owned it????
Is she still with team xzibit???
Originally posted by VISHES
cabra burger king is the place to meet for the runs....i havent been to orange grove maccas for ages.....i went passed the other day and i was shocked to see the new maccas!
I've seen you there a few times on saturday night -:uh-huh: :uh-huh:
  • 1 month later...
