I was working on the car last night finishing up a battery relocation and when I flipped my breaker my dash and most of the interior power was gone.  So I searched the fuse boxes and found that the main fuse blew so I thought it was just a blue moon type of deal.  I bought another one and it blew.  Does anyone know what that fuse powers besides the interior fuse box its a 75a grey and clear top.  I've read some forums but not much info but some said about it grounding off the alternator so I'll put some pics of the wiring on the ALT.  This is on a new built engine so it hasn't been ran yet I'm almost done and very close to starting.
https://www.sau.com.au/forums/topic/484309-r32-gts25-main-fuse-blowning/
9 minutes ago, GTSBoy said:
Are you seriously doing this without having the car's wiring diagram? It's freely available on the internet. I even made the best resolution scans I could and posted them on this very forum a year ago or so.
Yea I seen the post but its for a 33 not a 32.
well, yes the alternator is the easiest place to get that wrong; check the wire with continuity to battery + is on the alternator + and the alternator earth is correctly to chassis earth
I realise this, but...... it's still useful. Simple things like what the main fuse runs and what the wiring near the alternator looks like don't tend to change much. Notwithstanding that, the R33 drawings are out there too.
I checked it rn and no power is going to the alt.  Doesn't the main fuse send power to it?
11 minutes ago, Murray_Calavera said:
I have a Christmas gift for you.
Yes I know there is that one but it doesn’t really have info on the main fuse 75a which I believe is not on the 33.
3 minutes ago, GTSBoy said:
Wot? This one?
oh yea I'm dumb.  I'm getting another fuse tomorrow and will check it after work I looked at it rn and the positive to the alt was pretty loose and the ground was good not sure if the pos being loose will make the fuse blow or not.  In the diagram everything looks whats on mine.  I read another forum on my ALT there is not rubber piece on the pos terminal do you think its grounding on the ALT since it touching?  In the other forum he said he just put a rubber washer and it fixed the issue.
If there's no short to earth then there shouldn't be a reason for a loose terminal to cause the fuse to blow.
Well, obviously the + lead can only touch the thing that it is supposed to touch on the alternator stud. There really shouldn't be an easy way to short the + lead to the alternator body. There is supposed to be an insulating washer on most B+ studs (and on the D+ also). See below
Bosch Alternator Terminal Pattern Name? - BoostCruising
yea both of my washer are gone i will get some tomorrow and try the new fuse
before you pop another fuse or 10, check if there is continuity between earth and the fuse socket. If there is, you need to trace through that loom and find the massive short.  You didn't just get 2 unlucky bad fuses all of a sudden.
Edit, on second check it is clear that the positive wire's terminal is touching the alternator body in your pic. You don't really need an insulating washer, just screw the existing nut down to the body (tight but not overtight) then fit the ring terminal, then another nut to hold the terminal. That will keep the terminal well off the body.
And yes, adding a boot is good practice anyway, it will stop big sparks if you are working in that area without the battery disconnected and accidentally touch the terminal and anything else with a tool
I checked it today the one prong had power and one didn't so I think its fine there or if your saying to check the ground that comes off the alternator both had no power.
What he was saying is check for continuity to EARTH at the fuse box. If one side is power and the other side is continuous to earth, then when you put a fuse in, you have a short circuit (where you really really shouldn't).
Wasn't able to get to it today also have some washers coming tomorrow will update tomorrow
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
