 What's it not doing ?
Going up and down ?
I've dismantled a few out of my R33s over the years.
Some times they break the internal toothed plastic track that moves the antenna up and down, then its a replacement. ( might be difficult as your in England ? ? )
You used to be able to get plastic track replacements and you might have to match it up from another Nissan model.
Either way you still have to pull it apart
And times it was just build up of dirt and what looked like corrosion that was stopping it working.
A bit of fine metal polish and a heap spray lube got it going gain.
  • Like 1
On 11/26/2023 at 10:57 PM, GTSBoy said:
You want to listen to the radio?
I haven't even tuned in a radio station after a battery disconnection about 10 years ago. There's nothing worth listening to on the radio.
Not really, but I just like stuff on my car to work ...
Going up and down ?
Antenna got bent in the car wash ..
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
