pic 1 fan:
what is this fan for ? stock intercooler?
it is currently disconnected, car has a front mount intercooler.
pic 2  brackets:
two brackets by pass side strut tower
what are these for?
pic 3 intake hole/capped hose:
there is a hoses capped and large hole/ plate missing? on back of intake pipe next to throttle body
what is the hose suppose to be connected to and what is this plate missing?
pic 4 5 and 6 hood prop rod :
hood prop rod is not bent, but doesn't line up with clips to hold it, it hits
something electric sensor? that is on a bracket, what's not correct here?
I would also assume there suppose to be a prop rod bushing?
pic 7 brake line brackets:
where can one find the upper rear vertical brackets for brake lines, both are broke one front missing
thanks
Edited by JC71
https://www.sau.com.au/forums/topic/485139-under-the-hood-questions-er34/
Air con condensor fan.
Not sure about the brackets. They're not the same on the 32. Possibly for tank breather lines.
Traction control motor/throttle body. Hoses? Can't tell.
External air temp sensor for the climate control. And yes, bushing.
Dunno about the brake brackets. Probably NLA.
where is the External air temp sensor for the climate control originally mounted?
# 3 pic : this blank opening is on the back side of intake piping, just before the throttle body, throttle position sensor?
https://tfaspeed.com/products/nissan-skyline-r34-gtt-rb25-neo-tps-throttle-valve-switch
the hose that is plugged come right off the bottom edge of the bov, I believe.
Edited by JC71
Again, on an R34, I don't know exactly. But somwhere around there. We all relocate them to clear intercoolers, oil coolers, etc.
No. The actual TPS is on the actual throttlebody, which is of course, further along at the plenum inlet. It's on the opposite side of the crossover pipe from the throttle cable and bell crank that you can see in your pic #3.
The RWD turbo Neos have an additional ECU (actually, TCS ECU) controlled throttlebody where that blank opening is on yours, for the traction control system.
alright, so some came from Nissan, wide open like this, or was there a plate there originally?
so I can put a plate over this opening, and it wont or currently effect anything by not having it connected or open/closed?
and I would assume the Air con condenser fan will have to be connected in order for the a/c system to function correctly, I would assume its controlled by a temp sensor or such, I will look to see if hopefully its just been unplugged and I can track it down, other wise where does it wire to?
Edited by JC71
I have never seen a turbo crossover pipe casting without the TCS TB in place. Your photo does not do enough to show what is actually going on. That oblique angle does not tell me if that mounting point for the TCS TPS is open to the pipe or not not. If it is open, then someone has removed the TCS throttle, motor and TPS, etc. And yes, you will have to close it up somehow. If there are no penetrations on either the front or the rear of the crossover pipe, then you don't have to do anything. But as I said - I've never seen a casting with the mounts that doesn't have the TCS parts.
The Stageas had the same motor, but because they were AWD, they don't have TCS. So they have a different crossover pipe.
The air con will work without the fan - as in, it will run. It won't work well in hot stop-start traffic though. The fan is there to get some air moving across the condensor.
Yes, the wiring loom/plug for it is supposed to be within reach of the fan's own plug. If it's nearby, you'll find it. If it has been f**ked off, no-one can help you.
You really should look at the service manual. There are lots of diagrams.
The hose near the BOV has nothing to do with the BOV. It is probably the sense line for the Neo's boost sensor, which is usually mounted on the back end of the coil cover there, next to the purge solenoid. All this is shown inn the DRAWINGS that I keep referring you to.
The hoses near the battery look like someone's bodge. No-one can know what some wanker in the past has done.
did some google searching, and it appears alot of these rb25det neo from Stagea's have nothing in that TCS opening.
as far as that hose next to the bov, I found this pic and it is showing this hose, it has two short sections and a inline valve? or something, but did not find pic showing where it connects to.
as far as i can tell the hose that goes to the boost sensor is off the back of the top section of the intake.
as far as the Drawings you keep referring to, where can one get those?
Edited by JC71
That's a filter, and after the filter is the boost sensor. The ECU's boost sensor. Not the dash gauge boost sensor. The ECU's sensor is DEFINITELY connected to the crossover pipe. The dash gauge boost sensor is definitely connected to the plenum.
The drawings are in the R34 workshop manual (as I already said), which is freely downloadable after a brief google search.
did some google and I think I found that the two hoses by battery, must be for washer bottle, that is missing, the front outside temp sensor goes on bottom driver side edge of lower rad cross member. correct me if I'm wrong.
new question:
car has what looks to be the xenon style headlights,
what color are head light bulbs originally?
current outside corner lights are blue...
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
