CES Split dump pipes
  • Replies 56
Guys, CES is one of the Best exhaust fabricators in Australia
Goto www.cesracing.com.au to read about them
All ive ever heard about CES has been good
$650 for this; HPC coated is awesome!!
If we get 10 im in definate.
Guest darrinspencer
Wizard count me in for sure as long as i can pick up the dump pipe within the next couple of weeks. I am very interested... Also what would be the difference between the plain steel and the HPC coated?
The $650 price is for 10 steel pipes HPC coated
If we split them up, some with HPC and some without It will adjust the $650 price
Prices quoted were broken up as
10 pipes $530 each plus hpc $120 each total $650 each
5 pipes $550 each plus hpc $130 each total $680 each
So depending on what option we end up with the final cost may be affected
One thing Trevor suggested was that on Skylines with their fairly low mount of the turbo the HPC would have a less of affect and you could get away from not using it.
Apart form the high heat reducing affect from HPC, it also stops the mild steel pipe from rusting, which IMO is worth while.
There seams to be a few GTR owners keen to participate in this group buy. If it was possible to include dump pipes for an R32/R33 GTR in the group buy I think you would make up the numbers required a lot quicker. I would be keen for starters...
Lawrence
Guest darrinspencer
Lawrence
We need to get 10 people for 1 type of dump pipe not a mix up of both
CES make 10 at a time, hence we need to get 10 people together for 32/33 GTST to get the better price.
To organise a group buy is a pain in the arse for who ever organises it.
Some people want one, some are interested but do not confirm if they want one, some want one then pull out when it is time to pay which really stuffs things up as it has recently happened in my last group buy for flywheels
I am only doing this so I can get a cheaper price for my car.
If you want to organise a GTR dump pipe group buy feel free.
Guest darrinspencer
Lawrence
I will be now including GTR as aswell
I will update the first thread soon with prices when I can fit it in between work.
Guest darrinspencer
Lawrence
GTR and GTST are now included in the group buy
Please read the first thread for all the details and prices
Please read the group buy rules aswell.
Thanks
NewB question... what the hell does the waste gate do?? Is it essentially there to create less turbulence as the two exhaust streams meet at a similar velocity?? I'm not too sure.
BTW this will bolt straight on to a stock R33 GTS-t?? If so, is it a DIY jobby?
(In case ur not sure ,I am seriously interested in one of these... just depends on when I can get it etc.)
Cheers.
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
