51 minutes ago, PotatoCake said:
Went down and had a chat with him yesterday, nice guy. Will be getting a full custom hard pipe intakes setup done next week! Exhaust, im still figuring out what path to go down. Some are saying the varex's hang too low because of the valve it has at the top
The Varex is good if you want the ability to quieten down a really loud exhaust, and a fairly simple install if you have the clearance
In saying this, a well designed exhaust, that doesn't drone, and "close" to not being a "big heat signature" for the constabulary, is a better way to go
Noise does not = power, but a well designed exhaust that isn't "overly" loud will not negatively effect power, it will though keep the constabulary off your back
I had a Varex, and it worked well, super quiet when closed, but sounded like war when open and up it, I did have available "realestate" clearance issues under the old SS though running a 4" exhaust, and the Varex was the best option for me, as the space where the rear box went was available for the valve, so compromises were made to quieten it down
I have seen, and heard, alot of nice RB's with just some resonators and/or muffler/s, which, while sounding "beefy" were not obnoxious cruising around, and not something that draws unwanted attention, but, they did get real rowdy when up it
The trick is to get an exhaust fabricated that doesn't break your brain, or your passengers willingness to be in the car, on a Hwy cruise, i.e. no drone, and also not have your neighbours breaking your balls because their house vibrates and wakes their family when you roll in late at night, or when you head out early in morning, but it also sounds real good to the ear
Post up when your done, whilst I no longer own a RB, I do love their sound with a nice exhaust, especially when there's a lumpy cam lopping away
Nice, glad Jesse will be able to look after you.
As for exhaust, a couple of good quality mufflers should do the trick without the need for the varex.
  • 4 weeks later...
On 12/03/2025 at 10:07 PM, Milkmun said:
Have a look at JS Performance Garage, just did a bit of work on a 32 GTR.
Thanks for bringing this workshop to my attention, i didnt know about it before and Jessie did some Fabolous work on my car! Helps that its close to home as well, hate having to drive half way across melbourne for a decent workshop.
https://www.instagram.com/p/DIPwaQ1yHMe/?utm_source=ig_web_copy_link&igsh=MzRlODBiNWFlZA==
  • Like 1
Car looks clean as. You ended up getting quite a bit done 😂
So what's the plan for the exhaust?
Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.
Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
  • Like 1
9 hours ago, Milkmun said:
Curious to why you're not getting Jesse to do the exhaust, seeing that he has just done 2 GTRs with Aes valves.
I only found out about Jesse's shop after meeting with A4E and having a good chat about what direction to go in with the car and exhaust setup. I didnt want to go back on my word as thats a bit of a shitty move, especially since Luke took the time to meet with me and have a really good chat. Theres not many places that do that anymore, most of the larger commercial workshops churn through the process like a production line, quantity over quality etc.
  • Like 2
On 14/04/2025 at 9:46 PM, Milkmun said:
What's the time frame you reckon?
Exhaust end of this month, and then tune after that whenever there is availability. Still tossing up between a pure 98 tune or a flex 98/e85 combo.
The (lack of) milage in e85 isnt great. Start to get anxiety if i go for a long drive and there arent any united servo's nearby
But if you've got the flex sensor whats the issue? You just run what you can get your hands on.
I can't see any reason not to run e85 if it's relatively local to where you live.
Had a good chat with Ben from Danellos tonight about which direction to go with the tune, we'll do a flex setup initially, ill see what my thoughts are on 98 and then take it from there. I mainly one want or the other, i dont want to be mixing both e85 and 98 for a weird hybrid fuel combo.
This is very confusing. "flex setup" = being able to run 98, e85 or any % of ethanol.
If your tune only supports 98, that is not a "flex setup".
I don't understand your hesitancy for running ethanol. It's just better. It makes more power and is safer. What's not to love? Also it smell amazing lol.
Currently on an e85 only tune, but I barely get 200km from a full tank. Makes going for longer drives difficult, especially when u leave Melbourne metro as there aren’t many united servos, hence why I’m thinking of going more of a 98 setup.
And yes the smell lol. Any drive afterwards I need to have a shower and wash all the clothes I was wearing, it’s like someone made a Calvin clown e85 perfume and sprayed it all over me haha
  • Haha 1
The suspense is killing me lol.
Are you going to buy a flex sensor, then add the 98 tune to your current tune?
It sounds like your just going to delete the current tune and re-tune the car on 98 =/
If you've only known your car on e85, I don't think it will be long before you install the flex sensor and go back to running e85 when its available lol.
Ah, should have been clearer. Currently has a flex sensor installed all good to go.
like u mentioned, I’ve only ever known the car on e85, I might hate 98, but I have to try it out first. Everyone says the -5 turbos get pretty laggy on 98 octane tho…
Nice, let me know how you find the 98 tune
The availability of e85 won't matter with a flex tune. Can mix and match and never have range anxiety again. Only thing will change is your ethanol %.
This.
I'm confused by the whole discussion.
The only reason you would have a car with e85 only if it was track use and you only ever used e85. All other use cases you add a flex fuel sensor, do the flex tune (you only need to do a couple of % and then interpolate the rest) and then you put whatever the hell you feel like including a mix in the tank and it just works.
Want a long drive? fill with 98
Want max zoom? fill with e85
Got a half tank of 98 then find e85 somewhere? Throw it in.
  • Like 2
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
