hey guys, has anyone seen a black 1993 skyline GTR rego number AMK80G???
if you have can you please give me a call on 0409204820
this guy bought my car and hasnt changed the rego over and has been speeding and i keep getting the infringement notices. can you also try and get his name and where he lives.
any help will be great
thanks guys
https://www.sau.com.au/forums/topic/48620-anyone-seen-this-car/
you should have cancelled the rego the minute he drove off with the keys. Then its their responsibility to return the plates, get done for driving unregistered, etc.
Ring up the transport department where you bought the car and cancel the rego this second.
i wish i could. i sold the car and sent it on a transporter down south from darwin where i live. i signed the rego papers to dispose of the vehicle and he hasnt changed it over when he collected the car from the other end. i have phoned the police but they dont give a shit. this was almost 5 months ago now so im pretty pissed off.
Ring the transport department and explain the situation. You should have a signed copy of the transfer papers for a particular date. That should be able to establish that you disposed of the car on that date I would imagine so you are not liable for any fines?
Technically the car is still yours if title hasn't been transferred I would have thought - so you can cancel the rego at any time.
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
