Hi all.
So one of my major issues at the moment is my rear turbo leaking oil on the exhaust (and the general area). I presumed it was the rock hard super old drain hose, which it was not. So now I am in the midst of removing the rear turbo to get access to the banjo bolt that goes into the turbo oil feed.
As one of the previous owners accidentally? tore off the OEM oil feed hardline that reaches behind the turbo, they ran braided lines directly to the turbo, presumably PTFE.
Now, regardless if the line has rubber or teflon inside, is it just generally a bad idea to do this? I imagine these lines get quite hot being between the engine, turbo core and exhaust manifold. I suppose it's not too far fetched to think the line may even have melted.
I'd love to hear your opinions on this as as the replacement OEM hardline piece is 130 per unit. And cutting open the currently mounted line to see inside will mean I just have to get a replacement either way. So far I am hoping maybe the bolt just loosened or (god forbid) they forgot one of the crush washers.
https://www.sau.com.au/forums/topic/486240-braided-lines-for-the-turbos/
No it's fine. Heat sleeve is a thing.
With oil running through it it is unlikely. Engine off heat soak can be a thing though.
There is no way that you have a leak through the hose. That has pressure behind it and any small hole will turn into a large one in very short order. It is so much more likely to be leaking from the connection.
Thanks for the reply @GTSBoy
Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now.
I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.
Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
Take this with a pinch of salt, it's from someone (me) who got annoyed with turbos entirely.
I hated aftermarket lines. If I had the option to use hardlines with whatever turbo I had - I would use them, 10/10, 100% of the time. The only reason people go larger, heat resistent, shielded lines etc is because they have to.
And yes they don't last forever. Even if you spend big bucks on all the best heat shielding money can buy, with the best heat resistant, fuel resistant, oil resistant, radiation resistant hose, they get stiff and break down and just don't last the way a metal pipe will.
  • Haha 1
Would something like this be an option
https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html
I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff.
But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available.
I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 12 years later!
  • Like 2
I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free.
Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
  • Like 1
For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance.
Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down.
** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • WhatsApp+35796370243 Email: [email protected] Telegram: @tesgkm Vásárolj hamis pénzt, és segíts az embereknek szerte a világon elérni céljukat, hogy jó életet élhessenek, és megengedhessék maguknak azt, amit soha nem engedhetnének meg maguknak. Az én pénzemmel. Megvan. Valóra váltom az álmaidat, a világot eléd tárom, a közeli barátaid tisztelnek, az ellenségeid tisztelnek, és a legjobb életet biztosítom neked és a családodnak. hamis euróbankjegyek vásárlása hamis bankjegyek vásárlása Hol lehet hamis pénzt vásárolni? Hol lehet hamis játékpénzt vásárolni? Hol lehet hamis pénzt vásárolni? Valódi kinézetű hamis euróbankjegyek Eladó valódi euróbankjegyek hamis pénz vásárlása online észlelhetetlen hamis pénz vásárlása online hamis pénz vásárlása online az USA-ban valódi hamis pénz vásárlása online hamis pénz vásárlása online hamis golyók vásárlása hol lehet hamis bankjegyeket vásárolni hamis bankjegyek vásárlása online hol lehet hamis 100 dolláros bankjegyet vásárolni hol lehet hamis dollárbankjegyeket vásárolni hol lehet hamis millió dolláros bankjegyeket vásárolni hamis euróbankjegyek vásárlása hamis dollárbankjegyek vásárlása hogyan lehet hamis pénzt szerezni? hamis 20 dolláros bankjegyek hamis bankjegyek ellenőrzése Egy kényelmes otthon nagymértékben javíthatja az életminőséget. A pénz lehetővé teszi, hogy biztonságos, védett és kényelmes lakóteret biztosítson magának és szeretteinek. Milyen jellemzők vagy szolgáltatások tennék álomotthonná a házat?
    • Whatsapp+35796370243 [email protected] Telegram.@tesgkm Buy Counterfeit money and Helping people around the world to achieve their goal to make them have a good life for them to afford what they can never afford With my kind of money. I have. I will make your dreams come true make the world ahead of you make your close friends respect you make your enemies respect you and give the best life for yourself and your family. buy counterfeit euro banknotes buy fake banknotes Where Can I Buy counterfeit money where can i buy fake play money where to buy counterfeit money Real looking counterfeit euro banknotes Real euro banknotes for sale buy counterfeit money online buy undetectable counterfeit money online buy counterfeit money online usa buy real counterfeit money online buy counterfeit money online buy fake balls where to buy counterfeit bills buy fake bills online where to buy fake 100 dollar bill where can i buy fake dollar bills where can i buy fake million dollar bills buy fake euro bills buy fake dollar bills how to get counterfeit money counterfeit 20 dollar bills checking for counterfeit bills Having a comfortable home can greatly improve quality of life. Money can provide the means to afford a safe, secure, and cozy living space for yourself and your loved ones. What features or amenities would make a house feel like a dream home to you?
    • Whatsapp+35796370243 [email protected] Telegram.@tesgkm Money plays a huge role in our lives.Buy counterfeit money. It's needed for basics like food, shelter, clothing, and healthcare. Beyond that, it provides opportunities for education, travel, and personal growth. Financial stability can reduce stress and give people the freedom to pursue their passions. However, it's also important to buy counterfeit money, remember that money  isn't everything, Buy Fake Bills. for relationships, health, and happiness are equally vital. How do you think people can strike a balance between making money and living a fulfilling life? buy counterfeit euro banknotes, buy fake banknotes , Where Can I Buy counterfeit money, where can i buy fake play money, where to buy counterfeit money, Real looking counterfeit euro banknotes, Real euro banknotes for sale, buy counterfeit money online, buy undetectable counterfeit money online, buy counterfeit money online usa, buy real counterfeit money online, buy counterfeit money online, buy fake balls, where to buy counterfeit bill, buy fake bills online, where to buy fake 100 dollar bill, where can i buy fake dollar bills, where can i buy fake million dollar bills, buy fake euro bills, buy fake dollar bills, how to get counterfeit money, counterfeit 20 dollar bills, checking for counterfeit bills, Buy undetectable counterfeit money, buy fake money that looks real online, where can i buy fake money that looks real, where can i get counterfeit money, Money is a necessity! People need it to cover basic expenses like food, shelter, and clothing, as well as for savings, investments, and achieving long-term goals. Financial stability can reduce stress and provide peace of mind. What's your take on financial planning or money management?
    • Whatsapp+35796370243 Email: [email protected] Telegram: @tesgkm Kupujte ponarejen denar in pomagajte ljudem po vsem svetu doseči svoj cilj, da si zagotovijo dobro življenje, da si lahko privoščijo tisto, česar si z mojim denarjem nikoli ne morejo privoščiti. Imam. Uresničil vam bom sanje, ustvaril svet pred vami, naj vas spoštujejo vaši bližnji prijatelji, naj vas spoštujejo vaši sovražniki, in zagotovil vam in vaši družini najboljše življenje. Kupiti ponarejene evrske bankovce Kupit ponarejene bankovce Kje lahko kupim ponarejen denar Kje lahko kupim ponarejen igralni denar Kje kupiti ponarejen denar Pravi ponarejeni evrski bankovci Pravi evrski bankovci naprodaj kupiti ponarejen denar na spletu kupiti nezaznaven ponarejen denar na spletu kupiti ponarejen denar na spletu ZDA kupiti pravi ponarejen denar na spletu kupiti ponarejen denar na spletu kupiti ponarejene kroglice kje kupiti ponarejene bankovce kupiti ponarejene bankovce na spletu kje kupiti ponarejen 100-dolarski bankovec kje lahko kupim ponarejene dolarske bankovce kje lahko kupim ponarejene milijonske dolarske bankovce kupiti ponarejene evrske bankovce kupiti ponarejene dolarske bankovce kako dobiti ponarejen denar ponarejeni 20-dolarski bankovci preverjanje ponarejenih bankovcev Udoben dom lahko močno izboljša kakovost življenja. Denar lahko zagotovi varen, zaščiten in prijeten življenjski prostor za vas in vaše ljubljene. Katere lastnosti ali ugodnosti bi vam hišo naredile kot sanjski dom?
    • Whatsapp +35796370243 Telegram.@tesgkm O dinheiro é uma necessidade! As pessoas precisam dele para cobrir despesas básicas como a alimentação, a habitação e o vestuário, bem como para comprar dinheiro falso para poupar, investir e alcançar objetivos a longo prazo. A estabilidade financeira pode reduzir o stress e proporcionar tranquilidade. O que pensa sobre planeamento financeiro ou gestão financeira? Compre notas falsas online. comprar notas de euro falsas comprar notas falsas Onde posso comprar dinheiro falso? Onde posso comprar dinheiro falso falso? Onde comprar dinheiro falso? Notas de euro falsas com aspeto real Notas de euro reais à venda comprar dinheiro falso online comprar dinheiro falso indetetável online comprar dinheiro falso online EUA comprar dinheiro falso real online comprar dinheiro falso online comprar dinheiro falso online comprar bolas falsas onde comprar nota falsa comprar notas falsas online onde comprar nota falsa de 100 dólares onde posso comprar notas falsas de um dólar? onde posso comprar notas falsas de um milhão de dólares? comprar notas de euro falsas comprar notas falsas de um dólar como obter dinheiro falso? notas falsas de 20 dólares verificando se existem notas falsas A crise atual é realmente difícil, com muitas empresas e negócios a fechar, deixando as pessoas com dificuldades em sobreviver. É um verdadeiro desafio cuidar das famílias e pagar as contas quando as fontes de rendimento estão a diminuir. Que tipo de apoio ou recursos considera que seriam mais úteis para as pessoas afetadas?
