is it only the right mirror that needs to be replaced troy?
intrusion bars i will get my bro in law to do... so thats not too much of an issue but where do u actually get them from??
https://www.sau.com.au/forums/topic/49465-the-beast/page/3/#findComment-989185
  • Replies 73
oh when i make them i use 70x25mm box section and make it in 2 sections so you can get it in the door....then i join the two peices up by using 3 peices of 20x20 stacked on top of each other and i make those slide into each peice by about half the length of each 70x25 box section(telescopic)....then i weld it all up in place and by the time youve welded them it takes up the 7mm diffrence in the 3 peices of 20x20(20x3 =60...inside of main intrusion bar is around 67mm)make any sense?Why dont you do them yourself?You say you are a panel beater by trade,shouldnt be too hard for you......As it is your safety thats is at stake,and its usually only the rh glass that needs to be done...you could change the other side if you want to be anal and keep them both the same
https://www.sau.com.au/forums/topic/49465-the-beast/page/3/#findComment-989322
ni you must be stoked!!! My car made it to Sydney a couple of weeks ago, apparently waiting for parts for compliance?? It's been that long that it doesn't really feel like i've bought a car anymore, it's just this thing that i have to keep trying to move forward. It must feel great to finally get to drive the beast!
AND SHAN REPLY TO MY EMAILS/PM'S/MSN MESSAGES YOU LAZY BASTARD :P i need to bout this Masa kit...
what was the reason for your hold up ni? I had a 2 import approvals go missing.... :)
https://www.sau.com.au/forums/topic/49465-the-beast/page/3/#findComment-989366
sweet as thanks troy... my bro in law has the welder so i'll just get him to do it for me... hes a lot better with the welder than i am.
thanks for the instructions mate.
https://www.sau.com.au/forums/topic/49465-the-beast/page/3/#findComment-989662
hehehe yeah very happy its finally here... makes it all seem worth it :)
the main hold up was myself getting the money together in time... other than that everything else went pretty smoothly.
https://www.sau.com.au/forums/topic/49465-the-beast/page/3/#findComment-989674
nark come past my work i'll fix ya a mirror for ya :)
and yeah, it is only the right one that needs to be flat
hehehe cool... once i get a UVP for it i'll drive over ur side of town :P
https://www.sau.com.au/forums/topic/49465-the-beast/page/3/#findComment-989675
what's a UVP? oh wait... Unregistered Vehicle Permit??? Do you have details on that because my car might be down here in Melbourne before it can be regoed as well...
cheers.
oh and if you see or talk to Shan, tell him to reply to my various msg's!!! :)
https://www.sau.com.au/forums/topic/49465-the-beast/page/3/#findComment-989682
lol chinny... yeah thats what it is... u have to ring vic roads to get em... u can either pick em up or have it faxed thru... cant remember the costs involved... depends on how long u want it for.
https://www.sau.com.au/forums/topic/49465-the-beast/page/3/#findComment-989738
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
