guys im obviously going to need to buy a hiflowed cat and an exhaust to put on my car for street use.... but what catback do i buy? As in for what model? Does an S13 catback fit on a cefiro? or an R32 GTST catback?
https://www.sau.com.au/forums/topic/49590-catbacks/
i've been pondering this recently also.
if its straight through cant you just buy a generic high flow like in the for sale section, then just cut the pipe at the place (or disconnect the joins if its got joins there) and put the cat in between em?
With clamps off course so you can replace it when it gets smelly.
Or have I just missed the point totally?
https://www.sau.com.au/forums/topic/49590-catbacks/#findComment-989649
yeah i dont think it is a cat... i got under the car this morning and i dont think its a catback. Thats ok... im going to get a cheapo rear muffler with a silencer and then get some custom piping made up for it... and a hiflow cat of course :rofl:
https://www.sau.com.au/forums/topic/49590-catbacks/#findComment-999388
  • 4 weeks later...
i could harp on for ages but i'll keep it short and sweet.
good news.
S13 catbacks fit to the A31 with slight mods performed at an exhaust centre.
...so i hear.
I have a Cefiro and an S13, and I can't see how it is possible for one to fit the other.. They are THAT different
https://www.sau.com.au/forums/topic/49590-catbacks/#findComment-1029800
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
