hey guys/gals
my name is mick and i am new to the site and well the skyline scene so i thought this would be a good place to start, and hope that you guys could answer my questions.... i am picking up my R33 GTS-T on friday, it is completely stock auto with i think 2 & half or 3" cat back exhaust.... if some one could tell me how much power i can expect at the wheels from the stock trim... and then an estimate with the following mods:
FMIC
POD filter
exhaust
t3/4e hybrid turbo( roughly 14 psi)
aftermarket management
malpassi reg
any help is appreciated, thanks Mick
https://www.sau.com.au/forums/topic/49598-new-to-site/
i dont' know about 220rwkw .. maybe .. i just dont' think the auto will cut it ... i had an auto and i had 162rwkw with only a full exhaust, pod, and about 10-11psi ... everything else was fully stock apart from the horn ;) ... i dont' like the idea of having so much power on an auto ... u might as well have a manual
https://www.sau.com.au/forums/topic/49598-new-to-site/#findComment-990465
allready have a 250kw vl thats a manual... got rid of it for the auto skyline becoz back is playing up and i find it hard to drive the manual...... dont doubt the auto... becoz of course by that stage will beef it up with shift kit stally and so on... so with a healthy auto you think about 220?
https://www.sau.com.au/forums/topic/49598-new-to-site/#findComment-990845
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
