Here is information about the Type 0 and Type 1 and difference between the two.
TYPE-O has the following functions.
TIMER MODE-This mode keeps engine still running at idle speed after turning the key to off position, and cools down the engine and the turbo by circulating engine oil. This timer has manual, memory and auto mode. Manual mode enables you to set the after-idling time as you like in the range from 0 to 10 minutes (every 30 seconds). Memory mode is the one that several after-idling time is already set in the factory, and you can choose from one of those after-idling times. In the auto mode, turbo timer sets the after-idling length automatically by calculating it from engine running condition.
BATTERY MODE-This is the mode to show the battery voltage in its monitor. If you want, you can set battery warning, which warns you by warning sound and changing the monitor colour when the battery voltage becomes more than 16V or less than 10V.
TYPE-1 has the following functions in addition to two functions which TYPE-O has.
SPEED MODE-This mode shows you driving speed (in the range from 0 to 399 km/h) and also you can set the speed that warning sound will inform you if you drive over that speed.
ENGINE REV MODE- This mode shows you engine rpm and peak rpm. By setting warning function, you can also use this mode for gear-shift timing or red zone indicator.
STOP WATCH AND LAP TIME MODE-
In this mode, you can use this turbo timer as stop watch.
0-400 TIME MODE
In this mode, you can measure the time of 0-400m by using count-down start or auto start that sensed by car speed.
https://www.sau.com.au/forums/topic/499-hks-turbo-timer/#findComment-12830
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
