I've been searching around on this forum and skylinesdownunder, and can't find what I'm looking for.
Basically, I want to run HKS 256 inlet with 8.8mm of lift and HKS 264 exhaust with 9mm lift.
Is this possible without changing valvesprings / machining the head ?
At what point does one have to change the springs or machine the head ?
Cheers :(
https://www.sau.com.au/forums/topic/50035-rb20-cam-lift/
Cheers  :cheers:
Are they RB26 cams or RB20 cams?
https://www.sau.com.au/forums/topic/50035-rb20-cam-lift/#findComment-995732
v8eta: cheers for that mate ... just that someone told me once that i could use cams up to 9mm lift, and then a workshop suggested to me the other day that 8.8mm might be the limit :confused:
sydneykid: I haven't ordered the cams yet, but I will when I find out what lift I can use. I'll order them for my RB20DET. :cheers:
https://www.sau.com.au/forums/topic/50035-rb20-cam-lift/#findComment-995756
OK, the questions sounds simple but it's not, the particualr issue here is PCD. If the camshafts have been ground with standard PCD, then 9 mm lift may need a slight (very slight) touch up on the clearances. There are pictures on other threads on where to machine, but is is bloody obvious when you have the cams in the head. Don't be afraid, it's a die grinder and about 1 minute per lobe.
If the PCD is smaller than standard, then ~9.2 mm is OK. But you will need to check your valve lash clearances as there are geometry issues with using smaller PCD cams. These may require offset followers to correct the geometry.
Bottom line, don't just grab the first pair of cams you see with the highest lift that say you don't have to relieve the head. My recommendation is, make sure you get standard PCD cams.
The second issue is hydraulic followers, I personally haven't had any success with cams over 9 mm lift in RB20's. I end up with follower rattle every time, probably because the engines have done a lot of k's and the followers are worn and leak a little.
Hope that helps :D
https://www.sau.com.au/forums/topic/50035-rb20-cam-lift/#findComment-995851
So if I got a pair of 8.8mm lift cams I should be ok ?
One thing though, what does PCD refer to when talking about cams ?
Re 8.8 mm lift, I have used a number of GTR cams in RB20's and they work fine.
PCD = Pitch Circle Diameter. In a camshaft it generally expressed as the distance from the the centre of the camshaft to the point of the lowest lift, valve closed, sometimes called the heel. The point of the highest lift, valve open, sometimes called the toe. The lift of the camshaft is measured by subtracting the heel (distance from the centre of the cam) from the toe (distance from the centre of the cam).
Reducing the PCD of a camshaft is a trick used by camshaft grinders to get more lift. Instead of building up the toe they take some off the heel, the follower takes up this loss of PCD (if it can), so you end up with more lift.
A few simplified examples;
1. Standard camshaft
Distance from centre of cam to heel = 6 mm
Distance from centre of cam to toe = 14 mm
Lift of camshaft = 8 mm
2. Reduced PCD camshaft with higher lift
Distance from centre of cam to heel = 5mm
Distance from centre of cam to toe = 14mm
Lift of camshaft = 9 mm
Will not require machining of head as toe is 14 mm from centre of camshaft
3. Standard PCD camshaft, but with higher lift
Distance from centre of cam to heel = 6mm
Distance from centre of cam to toe = 15mm
Will require machining of head as toe is 15 mm from centre of camshaft
4. Increased PCD camshaft with higher lift
Distance from centre of cam to heel = 7mm
I have never seen a #4 for an RB but it is possible, so I always check the PCD quoted by the cam grinder.
Hope that helps :cheers:
https://www.sau.com.au/forums/topic/50035-rb20-cam-lift/#findComment-995953
So JiMiH, got thsoe cams sorted.
Im looking at ordering ASAP the following Tomei cams:
Inlet - 260/8.8mm , Part no. 1411260088
Exhaust - 270/8.8mm , Part no. 1412270088
I have adjustable cam gears to go with these puppies, should i just go 270 inlet as well or 260 both inlet , exhaust?
Im erring on perhaps sticking with 260s, but no-one botls cams into RB20s, lol, instead they bolt RB25s in:)
https://www.sau.com.au/forums/topic/50035-rb20-cam-lift/#findComment-1011295
Get the 270's all round Roy! Even if they give you reduced bottom end torque, the lope at idle will make women swoon and babies cry!
p.s. your car spends more time at idle than anything else! :(
You know what? You are right...LOL. Even if i aint quick at least my car will look and sound tuff? Response is for wimps, my top end is is going to make my ears bleed ;)
https://www.sau.com.au/forums/topic/50035-rb20-cam-lift/#findComment-1011364
Anyone got any idea how much these tomei cams are? and where they can be sourced for a reasonable price? ie not with 200% profit margin thrown on.
Thinking of a pair of 270 ins/outs. for an rb20 as well..
Im waiting to hear back from Greenline re-delivery times
see...
http://www.greenline.jp/catalogue/bcpartli...=R32B&intake=FI
https://www.sau.com.au/forums/topic/50035-rb20-cam-lift/#findComment-1011435
Roy let me know how it goes ... I haven't ordered my cams yet.
Was going to do it last week but ended up getting a new exhaust manifold instead as I still wasn't totally sure which cams I would order. The Tomei 260/270 idea does sound good though.
Are you getting new valvesprings with those as well or just keeping the standard ones? I've heard that with the Tomei cams the uprated valvesprings aren't totally necessary.
https://www.sau.com.au/forums/topic/50035-rb20-cam-lift/#findComment-1012021
Meh, upgrading the valve springs is for ppl that do things the proper way. :Oops:
Will see how it goes. No one can give me credible / reliable information concerning modding an RB20 so have to go on a fact finding mission. :D
If the std springs are no good then since i have a spare head i may do some DIY porting and put new springs in that, then swap over the cams and heads.
But im hoping that the cams will be fine with std sprigs
LOL th ebefore and after figures will be intersting :D
https://www.sau.com.au/forums/topic/50035-rb20-cam-lift/#findComment-1012040
They will indeed, and I'm definitely very interested in seeing them.
That's the thing with the RB20 ... not many people have really done a lot to them. Well, it appears not on these forums anyhow. So hard to get reliable information for these engines.
https://www.sau.com.au/forums/topic/50035-rb20-cam-lift/#findComment-1012055
It sux, even when speaking to workshops, it seems RB20 owners never really bother doing anything to them simply because it is so easy to get better power out of RB25/26/30s.
But it aint an R32 GTST without an RB20, and im hoping my car will be a quick R32 GTST with only the RB20, but cams are about as far as im willing to go. If i need springs to make them work then ok.
https://www.sau.com.au/forums/topic/50035-rb20-cam-lift/#findComment-1012412
From my understanding of old school love of the V8 :D it all comes back to cylinder filling. Short duration cams are good for maintaining good cylinder filling at low rpm but as revs rise they can cause a restriction. Up top it would choke two fold as you have a turbo strying to stuff extra cfm inot the cylinders.
Vice versa, big duration cams give good flow at high rpm but poor cylinder filling/velocities at low rpm. Throw a turbo into the mix and the physics of cylinder filling seem the be masked by sensibly sized turbos. Not saying that cams still dont result in power, but the good old turbo masks alot of inefficiencies/tuning of inlet manifolds, exhausts and even cams selection.
So im guessing to bring on power earlier you would want as much lift as you can muster with minimal increase in duration. How that pans out with your turbo selection and power band who knows, id love to know the cam specs of the GMS R31 GTS-R used:thumbsup:
DISCLAIMER: Im no engine building guru. The above is my basic understanding of internal combustion engines, even the above could be flawed. :)
https://www.sau.com.au/forums/topic/50035-rb20-cam-lift/#findComment-1012692
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
