Mods...both
Performance...GT-t mainly cause engine will be newer lol
Handelling...not sure
General performance...not much in it lol stock wise
Im selling up at the end of year to buy a 34, 33's are nice but they are getting old man. and they are as common as dog shit now
34 stockies go for low 30's...
33's range from shit ones...mid 10's to nice stockies high 10's and reasonably modded low 20's depending on whats on it
https://www.sau.com.au/forums/topic/50175-r33gtst-or-r34gtt/#findComment-997998
Guest RedLineGTR
From being in both type of cars. Depends how much money you want to spend. In those budgets I would only consider a "late" series 2 in the r33 gtst range at a minimum if you wanted a r33 otherwise I would say get a r34 gtt all the features, added options, cosmetic looks, performance etc all add up to the price of the R34 gtt and is worth every penny.
My 2 cents. Rob
BTW Your the one who will be sitting in the car most of the time (unless someone else uses it) try a seat in each car and which one your are more comfortable with.
https://www.sau.com.au/forums/topic/50175-r33gtst-or-r34gtt/#findComment-998010
I looked at both when buying my skyline and the 34 is definitely worth the extra price.
Whilst fundamentally the same, the extra refinement and newer age are a big plus. And also as previously mentioned 33s are getting very common, whilst there are a few 34s out there, nowhere near as many.
https://www.sau.com.au/forums/topic/50175-r33gtst-or-r34gtt/#findComment-998076
the neo motor has solid lifters and it's factory power rating is higher than the 33.
the only bad thing is 2nd hand parts is hard to come by with things such as suspension parts, body parts, interior dress up stuff etc...
but i thought it wasn't as easy to tune and doesn't take mods as well
https://www.sau.com.au/forums/topic/50175-r33gtst-or-r34gtt/#findComment-998124
I think I will end up saving for a R34, the do produce a nice torque band stock and are modify-able.. Just a little more pricey at the moment, but I'm sure they'll go down as time goes on, I'd love to do one like the one in your avatar torreto, or perhaps a black one..
https://www.sau.com.au/forums/topic/50175-r33gtst-or-r34gtt/#findComment-998372
33 -> cheap, everywhere
34 -> newer, better and more torque engine, cool styling (at least in my opinion anyway), not as common as 33s, nice dash, more boot space and also more backseat room :D The only downside is the price.
Ultimately the choice is yours, I have test driven a few 33s (modified and unmodified) and a few 34s. At the end the 34 is what I did purchased, I would go so far as to say that the 34s can be used for a family car quite nicely. :(
https://www.sau.com.au/forums/topic/50175-r33gtst-or-r34gtt/#findComment-999076
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
