Ok its been inevitable for the last 8 months, I need a new block!
I am looking at 1 thats located in melbourne just gotta get it crack tested etc
I have access to Nissan Genuine Parts at good prices (friend works there). I also have access to a good engine builder, who is also a family friend so it can be done at good price.
my thoughts are if the block is in good condition give it a light hone and use my current pistons with a new set of rings, rebuild it using std genuine nissan bearings, gaskets etc. not touching the head.
my other idea was if it needs to be bored rebuild it using something like forged pistons, but i am not too keen on the cold startup slap of this type, so maybe something like ACL race pistons or those hyperautetic (spelling?) pistons. O-ringing the head and buying a phat turbo.
Power output i was originally aiming for was 200rwkw and i believe this can be achieved with the std turbo and injectors? but will go for more power once i understand what my limits are.
I have a Microtech MT/LT8 and a GReddy Profec B EBC, current power output is ~174rwkw at 12psi, will be upgrading to a FMIC and Dump/Front pipe before car goes back on the road also.
have about $2/4K to play with
cheers Tim,
https://www.sau.com.au/forums/topic/50231-rebuild-time-suggestions/
I have 3 cars with forged pistons and none of them "slap", it is simply a matter of setting the clearances to suite. I suggest a long talk with "the family friend" should kill off that myth. :)
Do i need Forgies for an engine thats only gonna see round 15psi and probably 300/350rwhp if im lucky?
Spoke to some guys that get their engines built at the particular place, said he swears by ACL Race Series pistons.
On another note one of these guys took me for a spin in his VH Commodore equipt with RB20DET, HKS T300, External Gate, FMIC, EMS and Launch Control, was bloody quick!
Its not really a yes or no answer but it comes down to wheather you want a reliable engine or not, an engine thats going to last 5 years or 1 year. I carnt really predict the life of an engine but its upto you if you want forged pistons or not.
In my opinion; If your going to do it once do it properly, saves you pulling out the engine later on in the future.
With forged pistons you could have a more responsive motor as you could step down a size in a turbo and run more boost (20-24psi) to make the same power as the larger turbo would on say 16-17psi. + you could afford to have a tune that is slightly more aggressive.
You always get used to the power and want to pump just that little more boost in so for an extra $1300 the forgy's are well worth while.
Don't worry about slap etc.. That is a thing of the past. Unless the builder is useless.
hmm ok, ill look into it... the guy building it builds race engines.
what turbo should i look at then? i can get a brand new GT3040 for ~$2000 + external gate, but i feel this may be a bit too big for my requirements?
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
