the contact details is on the last page of the import approval doc u fill out.
They actually say on the answering machine thingo when you call that 'unnecessary enquirys may delay issuing your import approval' .
Not sure what to take of that, what do they do when you call them? put your approval on the bottom of the pile???
  • Replies 250
yeah just received my IA as well on monday.. faxed it thru on the afternoon of the 31st of September. so taking around 3 weeks to get here. been waiting to send that since Feb this year.. long wait coming to a end
I got my approval, contacted J-spec and was told basically. "Fux knows when it will get on a boat. They're all full." :hellpisd:
Oh joy, gonna be like last year when I finally picked up my 33 on Xmas eve, 17 weeks after I bought it in Japan. :boohoo:
ok so is there only one shipping company that comes to aus?
I just faxed mine in this morning (twice to make sure) and at lunch am going down to get an express post bag so they have the originals of my doco
man I was hoping to drive the f#$^*( thing before xmas. this was my present to myself :D
mark
mark, i'm in the same boat.
Give dotars a call (the number is on your import approval paperwork) and make sure they have received it, ask them how long it should take.
Tell your supplier in japan to find out when the next ship leaves that has space on it. There is a ship leaving early December, im trying to get my car booked on that, even though i don't have the approval yet.
Faxing is definately quicker at the moment.
I sent my application express post on 29/9 and received it today 1/11
As for shipping apparently up to 85% of car carrying ships is allocated to new cars atm
and everyones trying to get a space.
You do have the option of putting a car in a container as they leave weekly instead of at
the end of the month,but this will add at least a k to the cost.
Btw next ship to dock in freo is the Arcadia Hwy
13th NOV
well i just got an email from Geoff and he said that only 2 out of the 5 cars he had booked on the ship made it onboard.
the 3 were bumped off. he'll let us know who made it and who didnt. knowing my luck, mine will be sitting on the docks. :(
he also said that the next boat will be 4 weeks away.
steve
hope thats not the case steve
I have emailed craig this morning, I got my IA faxed through to dotars yesterday morning at 7am
then sent the originals xpress post for arrival today
I don't know how long the form takes, but I assume if they could get it on the next boat (like they were trying I beleive) then the form would be back to me before the car arrives
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
