I just realized, theres never been any mention of earthquakes in the Japan forum...
Well, the Kansai area and most of western Japan got hit by 2, yes 2 earthquakes tonight:
震度7pin8.gif震度6強pin7.gif震度6弱pin6.gif震度5強pin5.gif震度5弱pin4.gif震度4pin3.gif震度3pin2.gif震度2pin1.gif震度1
My area and dare I say Troys area too got hit by a level 3 or 4, while Mie (where I used to live) got hit by a level 5 intensity on the Japanese Omori scale.
What made tonight interesting was that we had 2 quakes, both within 2 hours of each other, both the same intensity, and both lasting at least 15 - 20 seconds (in Hyogo). Usaually a larger one is folowed up by aftershocks of a lower intensity... but then again I'm no goelogist so this might not be so uncommon, I don't know.
Tidal wave warnings are in effect from Tokyo right across to Shikoku, with the main focus on the Mie prefecture area (where the epicenter was, some way off the coast).
Anyways, thats enough action for one night, I'm off to bed.
https://www.sau.com.au/forums/topic/50373-earthquake/
I was in saitama tonite and felt a very small quake around 6:30pm
They have been happening on and off a fair bit recently in tokyo..
last week i was on the 7th floor at my school and one hit.
Maybe someone should post up some info regarding the great kansai prediction... similar but more power than the Kobe earthquake... that is expected to hit sometime soon. and destroy 6 million out of the 6.6million structures in the area.
https://www.sau.com.au/forums/topic/50373-earthquake/#findComment-1000848
Whats this about? Do tell
https://www.sau.com.au/forums/topic/50373-earthquake/#findComment-1001960
Just got woken up by another one... this is getting a little freaky now, as there is a typhoon coming our way later on this afternoon too, and as you can see the epicenter is in almost the exact same place...
pin9.gif震度7pin8.gif震度6強pin7.gif震度6弱pin6.gif震度5強pin5.gif震度5弱pin4.gif震度4pin3.gif震度3pin2.gif震度2pin1.gif震度1
This time the highest magnitude was 4 in Mie (again), and we acyually felt a level 3. It only lasted for 5 - 10 seconds, but still, in my time in Japan this is the first time I felt 3 quakes within days of each other... something must be brewing underground?
https://www.sau.com.au/forums/topic/50373-earthquake/#findComment-1002194
Damnit... Japan will be destroyed before I get over there. :P
Hehehe, you know, sometimes I think Japanese people want Japan to be destroyed, just so they can start over again...:headspin:
https://www.sau.com.au/forums/topic/50373-earthquake/#findComment-1002319
    • Thanks man, I appreciate that. I'll keep it in mind going forward, important to know.
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
    • Is Jackie home by Friday?
