I'm awaiting the arrival of an emanage from the states, with the ingition, injection, and boost harnesses (and sensor)
where (in peoples experience) are good places to get this installed and configured.
I dont really mind doing the install, but want it setup by someone who knows what they are doing with fuel maps etc ...
either south sydney (the shire) or north sydney / chatswood ish
cheers
https://www.sau.com.au/forums/topic/50606-emanage-installation/
yeah, tell me about it ....
luckily i can work from home for half the week tho ...
the 'dont blow up the coils kit' well, from reading up on the emanage, the latest version of the firmware has this built in, was to do with supplying a constant voltage to the coils, and aparently this has now been turned off ... also, there wre some reports that the new harnesses are comming with the zenier diodes built in ... might just get some zeniers anyway ... not exactly expensive, and worth it to save the coils i think !
not gone for the warning light thing yet, will see if it does it as it appears that some do and some dont ... strange ... if i need to i'll grab one from AU somewhere ..
got any thoughts on an installer ?
cheers
That's a long way to drive ot work every day, tangO.
Did you also get the "don't blow up the coils" kit?
And the "turn the engine warning light off" kit?
I don't know of anyone down your way that deals with the e-manage??? Come to think of it...they are thin on the ground up here too!
I've been running the zeners for a while now, no problems, I'd recommend doing it even though they say the software is fixed...as the voltage drop over the zener brings the trigger voltage down from 5V closer to the factory trigger voltage.
I'm also 99% sure your checklight will be on, as you have the same coils as the R34..which means the diagnostic system in the ECU will detect the same 'problem'
You can do a fairly good tune yourself using the 'consult' to pull your factory map off the ECU and adjust tune through the e-manage...then just run along to a dyno to check out how you went :cheers:
hmm
ok thanks
forget to mention that the pc cable + software is comming with it too ...
oh also, what ranting are the zeners you get ??? 3.3v ?
cheers
full cost including shipping from the US is $640 USD
from the nice people at
http://www.mohdparts.com/emanage/
They currently don't have any of the pressure sensor / harness in stock, so am awaiting for it to ship from japan to the US, then from the US to AU ... sigh ... could be a while ..
couldnt find anyone in AU that would come near that price with all the harnesses
Wow, a full kit, or "set of kits" in Emanage speak.  How much did it cost, if I can be so rude?
Yeah I used 3.3V 1W zeners.
haha you'll end up like me...an ambassador for GReddy, current electronic bullshit stands at-
e-manage
software + cable
harnesses injector + ignition
ignition signal adapter
knock sensor harness (for sale)
Home dodgied-up O2 sensor harness :cheers:
BTW Mohamed from Mohdparts is a champ....I've dealt with him a lot over the past year and have never found anyone so helpful.
lol ... nice
thanks, whats the O2 sensor harness you have ??? got a schematic or something for it ????
and yeah, had a few emails bouncing back and forth, and he seems like a genuine guy, seems pretty helpful ...
e-manage
software + cable
Please don't swear at me ... :cheers:
no, its a manual ...
not bagging anyones car here, but why would someone buy a car like this, with a sludge box ... personally couldn't do it ... but thats just me ...
I'm from the UK where autos are for only 2 types of people
1. old
2. disabled
sorry ..
:rant:
Have you got an auto?
hmmm
cheaper power fc ??
640 USD = 927 AUD, then there is fitting + dyno days to set it up etc etc ...
i have not managed to find a power fc for a gts-t for under $1400 new ...
besides, i could use paypal with them, and have some UK pounds still sitting in an account in the UK (linked with paypal)
well, not sitting there anymore :rant:
Oh I thought it must be an auto cause you chose an Emanage over the cheaper Power FC, sorry. :cheers:
Disabled....ppppffft watch you language about my slush-box :rant:
I wired the O2 sensor into the boost sensor port of the e-manage...which you won't be able to do as you are getting the boost sensor harness....basically anything that outputs a voltage between 0-5 volts can be plugged into it and logged, resolution is changed through the real-time data logging on the software :cheers:
I bought a Power FC for $900, last month and one this month for $1125, that's with the Commander and it came from Nengun.
Power FC fitting was 8 minutes, remove LHS kick panel, unplug std ecu, plug in Power FC and drive to dyno. As for tuning, I seriously doubt that anyone could fit and tune an Emanage (fuel and igntion) faster than a Power FC. So fitting and tuning together would be cheaper or at worst maybe the same.
I will be very interested in how you get on though. I have an auto Stagea (so no Power FC) and I am looking at an Emanage for it. Please post up the results. :cheers:
dammit - now yo uhave me thinking ...
the monies for the emanage have not been taken, its going to take about 6 weeks for the emanage to arrive ... powerfc from nengun ....
hmmmm
ok, so the pros and cons ... ???
will the power fc plug into my laptop for realtime stats etc
hmmmm
With a Datalogit you can tune it and perform data logging to your heart's content. Refer to www.datalogit.co.nz for the cost of the datalogit software. There are a couple of extra outputs from the Datalogit that might come in handy, we use the intercooler spray for example.
There is really no comparison between an add on (piggy back) solution like an Emanage and a full ECU. Power FC = Full Computer. There is so much more you can do, if you want to.
With the Power FC we bought last month, I chose not to have an Commander, the owner spent the money (plus a little bit more) on a Datalogit instead. I like the Commander though, it's great for quick diagnostics and it saves buying quite a few gauges.
More to think about :cheers:
gah, yes, lots more to think about ....
i'm now leaning more towards a power fc ...
tha lack of emanage tuners in sydney is not doing the emanage any good either ...
plus the ease of installation, and the lack of the wifes 'omg i can't believe you're spending xxx hours on the car again'
hmmm
nengun here i come (maybe)
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
