I'm asking this on behalf of a mate with an RB20DET powered s13, when he starts the car up sometimes (usually in the morning) it has some white smoke coming out for a bit? Give the throttle a stab and more comes out! But after he drives around for a bit it's all gone and is back to its rich black smoke. I thought ring lands, turbo seals? Any ideas?
https://www.sau.com.au/forums/topic/50612-rb20det-blowing-white-smoke/
sounds possibly like a crack in the head gasket ....
does the white smoke have a blue tint to it, or is it totally white ...
blue tint = oil being burnt
just white = water vapour ...
just my 2p worth
If it is only for a short time in the morning i would tell him to not worry, it will be moisture in the exhaust.
If it constant, its water leaking into the combustion chamber. ie headgasket, cracked head.
Id be going with the first option, dont worry about its, its normal on cold mornings
White smoke can also means burnt oil, which could be ringlands as you mentioned.
If it blows white smoke when he backs off the throttle after heavy load (on boost) then I'd start worring but if it only does it in the moring sounds more like moisture.
Does the smoke have a smell of any kind ?
Could it be that overnight water is slowly leaking into the combustion chamber? Then after driving it for a wee while you blow out all the water.
Tang0 is right, if it has a slightly blue tint to it then its oil burning, if its just white its water. Check for an oil film in the coolant or for bubbling in the coolant caused by exhaust leak. Another thing to do is an oil change and inspect for a 'milky' effect in the oil. Those are all symptoms of a blown head gasket.
could be turbo, but normally takes a few minutes for the turbo to warm up and burn the oil.
if its oil regardless of colour on a still day itll hang in the air, vapour pretty much disappears straight away.
It will more then likely be your ring lands on your pistons, Which will be causing oil blow by. The reason it mite only be happening in the morning is when your motor is cold your pistons contract, allowing small amounts of oil.
Until the pistons heat up sealing the cylinder, stoping the excess blow by happening. Which will cause a build up of oil in your turbo. Once it becomes warm it will burn the excess oil.
HiGTST89 a couple of quick tests will rule out the possibilities.
#1 Does the radiator water go down over time? If not then it's not a head gasket leaking water in to the combustion chambers.
#2 Check the spark plug colours? If they all are the same colour then unlikley to be rings. Unless he has really bad luck and busted all 6 at once.
Hope that helps
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
