  • Replies 57
Edit: Hang on a minute isn't your mrs name Melissa?
And it just so happens a "Melissa" served you...2+2=BS
Mates rates / Trade prices etc don't count - UNLESS you are prepared to get the item for the rest of us at the same cost!
Otherwise you can't go around saying they cost $12, hopefully you understand that otherwise I can feel a keystroke-warrior-session coming on :confused:
LOL, you actually went to the trouble of scanning a receipt :D
It must be cheaper for Z200 because the Z202 - which is the one I have is MUCH larger and nobody has it for less than $20 - NOBODY!
still LOL :)
See attached photo
My misses works at the comm bank and yes her name is melissa also, but no connection to who ever the chick i bought the parts from in narre warren. I can go take a pic of the melissa chick that works there if ya like :)
PS i had the receipt laying around on my table so i took a photo of it. The Z202 is just bigger but doesent really do anything different!!
I can go take a pic of the melissa chick that works there if ya like :D
LOL, only if she is HOT!
ok - well it was worth a try :cheers:
Maybe I will grab a z200 - problem is their usually out of stock at A'barn, Eastcoast & Kmart!
The reason I used a Bigger fuel filter is that I have heard people say to put in th biggest filter you can fit as this will either A. Last Longer or B. Flow Better or C. Both!
End off-topic :)
There are special socket bits that are made for them. I got one in my socket set. When you say buy one that fits a vl, i take it you talking about socket bits, coz it was my impression that all spark plugs are the same size. So as long as you have a socket bit that will fit a spark plug then you should be right to go. Did that help any????????????
oi big bhoy hook us up with the location of your fuchs dealer...
isn't there a fuchs employee on this forum? can he hook me up :)
I need to change oil, oil filter, fuel filter and sparkies.
Also I was told that Skylines came stock with 0.8mm gap sparks. I know my HKS Idium ones were anyways. I've since gone to copper which I have a sneaking suspicion are 1mm because they keep fouling.
ok, well the big secrect is Waverley Auto parts. its at 7a Aristoc rd Glen waverley 9560- 3400 . They sell all fuchs stuff, as well as exeedy clutch's etc etc. They can get anything you need really and possibly drop it off to you. Give them a call and see what they can do for you. I know a few of the people that work there and have always got the best prices on everything for me.
isn't there a fuchs employee on this forum? can he hook me up :D
don't you have a GTS with a 2.0L NA?
io don't think gap is going to be an issue if that is the case...
yeah kinda....i was talkin about those long yellow sparkie wrench things that you buy from autobahn with the funny T at the end that already has a socket on it. but it looks like i can use an ordinary wrench right?? just have to make sure the socket fits the hole yeah??
You can either get one of those yellow things, or just get a socket that fits on a normal wrench thing. They look like normal sockets but are a bit longer and have a rubber insert for gripping the spark plug.
Oh and they come in different sizes, skylines use 16mm plugs so get one that is 16mm or else its a pain in the arse putting the car back together to drive to the shops to get the right one.
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
    • You sir, big win tonight. Precision never supplied compressor maps in the past and Idk when they started, but it seems they only offer for a few of the older gen2's which is exactly what I have. I punched in some numbers and seem to have gone with the wrong turbo. 600-700whp isn't in the most efficient area and is close to the choke line. 800whp is well off the map. Punching the numbers into a 68mm gen2 turbo map is bang on in the center. Here I was thinking going smaller would shift the power band down, but in reality it would just make it so much worst due to my rev limit. I would have never thought.
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
