Hmmmm...... I didn't put that very well Factory wheels 16x6.5 with 205 50 16 Vrederstein Protraks weighed 19.25Kg each.
Weds 18x8 front with Yokohama Grand Prix 235 35 18 weigh 18Kg each rears 18x9 with 265 35 18 weigh 19.5Kg each hence total save of 2Kg
Current ride hight is 255mm rear 245mm front from wheel centre to guard arch. I don't remember what the standard is does anyone know??
I got them from a used car salesman.......so I know I got a good deal...(:D;):) )
Primo..... a familiar figure in the for sale forum......we went up there on Sunday and Mick bought the R32 from him as well. Good news for me.......should extend the life of MY gearbox by several months at least.
You can now look forward to seeing two Silver 4 doors at Willowbank
4 Doors Rooooool!!!!
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
