drift can you post up your pics of your setup
did you need to modify any of the mounts or move anything under the bonnet
where did you source the kit from was it local (ie perth)
who installed it (you or a tuning house)
can you get more
how much
must sound like this is 20 questions but everyones a little short on information at the moment so anyone who knows anything is going to be bled dry for info atm
I will get some tomorrow and post them on my site.
We put it back to standard for compliance then bolted it back in a couple of hours and we wernt rushing.
It came with the car but is standard Blitz Stagea kit avialable through most shops, email [email protected] for a price as that is who I get my bits for my car from if they suit Stagea only, I have some body bits coming.
We put it back our self, bit of fairing was already cut out, I will get photos off Jeff at C-Red's car and a standard one tomorrow to show difference.
can you get more
Most Japanese Manufactures make kits to suit the WAGON,
how much
Well price varys and yes you do pay for what you get, I will get some prices through some contacts to set a group buy, but I am 100% sure R33 will fit.
Dont worry ask away, because I deal with the complyier and I think they are the best car at the moment so I know a bit about them.
We will pass our RAWS on a Toyota tomorrow but I still drive a Stagea and it will only be sold for an Autech Version.
Anytime and dont forget to remind me.
  • 6 years later...
To put a end to it all the r33gtst autobarn88 kits fit stageas.
I have 1 on my car its just like fiting it to a r33.
U need to make longer lower brackets and the hole is in a slight dif spot.
I would be careful with ur mods on s1 stageas thow.
I have found out that the ecu dose not really like to have changes. I talked to Cred in perth au and was told a good mod for s1 is to
add a piggy back ecu to the stock ecu like haltech platinum sport 2000.
The stock ecu in s1 controls every thing including the auto fit incorect will cause lots of probs. Was told the stock ecu is the shitty ecu on eney rb
The gain is eney where from 30 to 40 hp on stock motor and 50 to 100ks per tank
I think in the 7 years since the last post we have sorted out the intercooler options :thumbsup: . And yes S1 ecus are hard to chip - Greddy E-manage or Haltech are options or stick in a manual box and a Link!!
I just had a just jap kit put in my car, can't say exactly which one as I got it used of another forum member but yeah it bolted straight in only had to have a small chunk of the reo bar cut out to make it fit, pretty sure it's one of the cooling pro stealth kits which go for about 300-400 bucks, they aren't as pretty as blitz etc kits but it does the job and the engine bay looks very close to stock
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
