A friend of mine just got a r32gtr ... nicely modded and produces alot of power ... dont' know the exact numbers but its fast!! ... N1 turbos, big cooler, runs lower boost than normal with those mods, probably for reliablility.
anyways he says that his car oversteers alot in corners and he gets freaked out. he came across this article
http://www.skylinesaustralia.com/forums/sh...+torque+control
and was wondering if any of u guys have tried it?? or what other things have you tried to make it handle much better in the corner?
also, the car has ohlins on it, and slightly lowered from what i can see, i'm not to sure about what it has for struct and sway bars, i'll check that later.
thanks
https://www.sau.com.au/forums/topic/51103-r32-gtr-diy-torque-splitter/
sway bars, tyres, ride height, wheel alignment, all seem to play a roll in it
if you power out of a corner hard i find the arse does come out, but not like a rwd, if you keep on the gas pedal, and point it where you want to go (dont overcorrect) it corrects itself... thats the idea of the ATESSA, if you dial it up to 50/50 full time i think it may do bad things
This link is an interesting read. Deals with modifying torque split control.
http://www.autospeed.com/cms/article.html?&A=0060
GTR's are complicated beasties eh?
Revision Ah, sorry for the dodgy link. I'm not subscribed to Autospeed either. If you try this http://www.google.com.au/search?hl=en&ie=U...+g+sensor&meta= and click on "godzilla tamed" it gives you the complete article for some reason.
if u use ne other options, other then 50/50 full time rear and normal, the transfer case will be constantly slipping wearing it out super fast, as with 50/50 your atessa pumps will be constantly working therefor will wear out faster, best just to get used to the way the car works, learn to work with it and it will be unbeatable around a corner.
Rear Steering is not your friend, the first thing I would do is lose the HICAS. Get rid of that fidgetty rear end, that makes you worry that it's going to let go. Tell you friend that the race GTR's never ever ran the HICAS, that usually seals it. :thumbsup:
I've been doing some sniffing around and it seems that the 32's are more tail happy than the 33's due (partly at least) to the tolerances in the transfer case clutch pack.
The 33's clutch pack is partially engaged at all times. This should be achievable with the 32's transfer case as well by using enough of the thicker packers in between clutch plates.
I haven't got an r33 manual to check the figures. Anyone who has, please check it out and let me know.
Also investigating retrofitting v-spec 33/34 ATTESSA computer for faster reaction.
Hi, the car Hippy is talking about is mine.
I've just ordered a Super HICAS electronic locking kit from GRID in Japan
http://www.grid.co.jp/en/prod/prod7.htm
Should take out the unexpected twitches when on the limit. I hope the package is as reliable as physically locking the system, has anyone had any experience with this gizmo?
Sounds interesting about retrofitting either the R32 Attessa-Pro from the V-spec models (If you could ever find one) or a v-spec 33/34 attessa system. I recall reading somewhere in HPI or Zoom that apparently the controller in the attessa (non pro) monitors data @ 100 cycles per second, where as the attessa-pro is much faster at 400 cycles.. does anyone know how much of a difference this would make?
I have that article and he said no difference at all. Apparently just feels a bit smoother in the car but as far as handling goes no difference.
I think the different software would probably give you the difference. I found a post on a UK Skyline site where the guy said he fitted an R34 ATTESSA and the car then handled like the R34.
Ok apparantly the link doesn't work once pasted.. though just do the godzilla tamed google search and full access is granted.
GTRman1992, this is a taken from the last paragraph of the article.. perhaps you missed it?:
"It's hard to believe, but the electronic mods have made more difference to the handling of the GT-R than any other suspension modifications I have ever made to a car. And that includes the changing on previous cars of wheels, tyres, sway bars, springs, dampers, bushes - the lot. The difference simply cannot be overstated. And I might add that now the cat's out of the bag, a number of GT-R owners who had previously told me how wonderfully their cars handled have modified their torque split control system..."
Check it out guy's, some interesting points are made.
To access the DIY ATTESSA Torque controller article go to
www.autospeed.com/A_0060/article.html
or just type: godzilla tamed
in google and you should be able to access the full version
Yeah the link didn't work, but the google search did. Thanks for the tip Conrad. Reading now!
Richard
I take everything Julian Edgar says with a grain of salt. Having read a lot of what he has written over the years I can say I believe that he has some weird agendas. That article was published many years ago and I have personally tested the mods out on the road and the track. All it does is make the GTR understeer all the time, maybe this made him feel safer, but it just made the GTR slower. This was particularly noticeable around the circuit. I am not the only one with that opion, the article has been discussed and dismissed by many people.
It is also worth noting that the car involved was Julian's own and he sold it shortly after and has done nothing but whinge about it ever since. Maybe he has tall poppy syndrome, because he appears to like nothing better than knocking down icons.
My opinion anyway :D
My opinion anyway ;)
Yeah, after reading the article I didn't really find it very helpful. All he did was basically bag the GTR and say how bloody special his liberty was. and then describe a mod that no-one who's not an electrics genius can make. Very helpful.... :D
Richard
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
