  • Replies 60
I also have a aotomatic turbo R33 and was looking at buying a after market ecu like the apexi pfc and been shopping around 4 a good price and doing sum research about them 4 my car and i was speaking to a company on brisbane southside called fist performance and audio and he said u can use the pfc on the auto and it will work but he has to order it from japan if wanted it .
I think he was just trying to sell you a PowerFC - unless of course there is a specifcally reprogrammed "auto" version around?
I have seen Power FC for Toyota autos, but never Nissan autos. I have no doubt the manual Power FC will run the engine, I have driven an auto R33 GTST with a Power FC. The engine runs perfectly, exactly the same as a manual R33 GTST. But the gearchange quality was crap in my opinion. It flared on up changes, swapped between gears under even load and the kick down was eaither lethargic (sometimes) or viscious (most times). All of these symptons are logical in light of the manual Power FC not having the programming logic for ignition retard and cut during gearchanges.
I should point out that the owner was completely happy and was quite willing to sacrifice a "small amount" (his words, not mine) of gearbox niceness for the power he got from the Power FC and its tuning. So until the gearbox eventually fails from this excess loading, it comes down to personal opinion. I don't know that I would want to try and claim warranty on "personal opinion".
Since I want to keep the standard gearbox niceness and life, retaining the standard ECU auto programming logic is a must. Unitil I find a guaranteed replacement ECU that is. :D
  • 6 months later...
its actually on a s13 with sr20det but think it would be similar.
the problem is the fuel pump i think, its not priming when you turn the key on, and not running at all.
even when you directly wire it into 12volts and it runs still is not starting, my friend seems to think the power fc has to "see" the fuel pump.
anyone know the water temp sensor voltage when cold?
What have you done about the Park/Neutral switch from the auto? If you don't switch it on or bridge it out, the car will not start. ;)
ok, a little background info to help you.
the car is a 180sx s13 1991.
it was manual, converted to automatic - working fine with stock ecu for about 1.5 years.
when you plug in the power fc, the car will not start and the fuel pump won't prime or run.
we believe it is because the power fc thinks the water temperature sensor is faulty.
in the menu it shows that the Water temperature sensor has a voltage or 4.88volts when cold.
so i plug in the standard ecu and my consult board, the water temperature sensor is working fine, showing the correct temperature.
ok so now the car is heated up with the water temperature around 60degrees.
we plug back in the power fc and sure enough still 4.88 volts for the water temperature sensor. obvously the power is not even reading it properly.
the power fc shows this voltage as an incorrect voltage, meaning it thinks the sensor is broken, it definately is not.
my guesses:
-power fc is faulty
-power fc is wrong model (there are 3 or 4 models for the s13 alone)
-standard ecu was the wrong one for the model and sensor have been changed to match.
(the sensors were changed in later models)
NOPE looked on fast and websites and it is the right ecu for the car.
also checked the model of the power fc out and it is the correct model.
we are stumped.
also when we plugged in the power fc the first time, even when we pushed the throttle the TPS voltage would not change, the second time it was working fine, which makes me lean towards faulty power fc.
this power fc has been bought new ordered from apexi japan.
More than likely you have either not plugged it in fully...or you need to run thicker gauge wiring to the battery for the 12v source.. anyhow, i'm just regurgitating..
It's all here in the very excellent PowerFC FAQ by paulr33 :)
http://members.dodo.com.au/paul/skylinesau...erfc-faq.htm#18
I just wonder could PFC fits R34 GTT auto? The reason i'm asking is because even i shifting it manually,i felt the gearbox is not shifting/response fast enough in the high RMP.
Is any GTT auto mates has the same feeling as mine?
cheers
steven
Hi Steven, no it won't work, not even close. Nissan automatic ECU's have shift logic (eg; they cut ignition on gearchanges to smooth them out and help the gearbox to last longer). This extensive amount of logic is not programmed into Power FC's, I guess Apexi figured they would have to charge too much or they don't want to get into auto gearbox programming.:P
It's all here in the very excellent PowerFC FAQ by paulr33 :D
10 points to predator, yep my friend didn't use a socket set each time and it wasn't all the way in on the plugs.
sorry for wasting your time! ;)
Was looking around for an ECU for the auto too. Like Sydneykid I'm not keen on sacrificing long-term durability though. At this stage I'm looking at getting either an e-manage or SAFC, maybe SAFC because it looks easier to tune. Obviously it won't give the performance kick of a full chip replacement but I guess that's just life hey :cheers:
As far as quick shifting goes, there was a member on here called Dragon, who bought an upgrade chip which shortened the lag time between shits, not sure who made it though?
Most of the guys with the autos can run the e-manage with no problems, my one has been serving me fine.
Nissan automatic ECU's have shift logic (eg; they cut ignition on gearchanges to smooth them out and help the gearbox to last longer).  This extensive amount of logic is not programmed into Power FC's, I guess Apexi figured they would have to charge too much or they don't want to get into auto gearbox programming.:cheers:
Just a thought -
the big killer of Autos is heat, and the slower the shift the more heat they produce. (but the smoother the ride for the general public)
The shift kits that are being sold through the group buys section seem to be a hit, and they too give quick shifts, and reportly wont harm the longevity of the auto.
SK, are you comming down to Malalar soon? the offer is still there if you want to try out my auto R33 with the PFC.
SK - where is the Shift Logic kept on Nissan Automatics? Is it on the Main ECU or the second Auto ECU?
I wonder if you were to swap the Main ECU's from an Manual into an Auto from a same model car if it would work?
If the Shift Logic is kept on the Auto ECU i see no reason why it wouldn't work.
If that is the case then the guys doing remaps dont have to worry if the ECU they're working on is from an Auto or a Manual car. Right?
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
