It's a good read, but the part numbers and specs don't match with what the garrett distributers in australia (MTQ) are selling. It appears the relevent catalog is the "Ballistic Concepts" catalog as found on Ray Hall and GCG's websites.
I rang MTQ for a price on a GT30 and they didn't recognise the part number i gave them (out of the Garrett 7_17_13 catalog). They said they had 2 GT30's there, the SB8006 and SB8006A. The specs they gave me matched what is in the ballistic concepts catalog.
My conclusion is that the 7_17_13 catalog is for the USA market only????
This is because only the REAL GT30's , GT35R's etc use the REAL GT compressor wheels . Turbo shops are only too willing to sell you the TO4S versions because they're cheaper and OEM on many DIESELS . Look at it this way HKS have NEVER used TO4S wheels in their range period . This is not to say that only HKS spec GARRETT GTBB's work , only that they don't like/want stone age compressor wheels either . As a point of interest TO4S wheels were available in the mid late 1970's , the BCI-18C (six bladed wheels) are about 15 years newer technology and also a generation later than the TO4E series .
When the demand is high enough for the right turbos thats what the turbo shops will sell , till then find someone who will import them and reap the benefits .
If you get hit by the customs stick and paying premium DHL/UPS shipping can cost as much as $2,000. Get one in via EMS for as low as $1700 - that's just from an online shop such as www.cheapturbo.com. As always, helps to shop around.
Correct me if I'm wrong , the turbo you mention is called (by some) GT2540R . This monstrosity has a major imbalence along the same lines as HKS's GT2540 only worse . The drama (aside from the stone age wheel) is that the turbine is too small to power the compressor wheel . Is is imperative that the balence of compressor wheel to turbine wheel is close to ideal . The yanks made a rough rule of thumb that the major dia of the turbine should be within 15% of that on the compressor wheel , in the above case 48 trim TO4S= 76.2mm and 76 trim NS111 turbine = 53.8mm . In this case it comes to approx 71% .
The real world experience of this is that you need higher exhaust gas speeds to drive the compressor into boost than would be the case with a properly speced turbo . So more revs to get it going and more exhaust restriction once it does . Hence lag in the first half of rev range and overheated detonation friendly EGT's in the second half . Talk to Brett from GCG , his customers are getting as much power with the GT28RS (60mm comp wheel in TO4B cover .86AR exhaust housing with same NS111 turbine) as those with the GT2540R . I see this happen all the time , people look at the compressors performance potential a judge the turbo by it . What people really really N E E D ! ! ! ! to do is look at the turbine and housing FIRST . This area is the main bottle neck and has to be sorted first . I realise its difficult and expensive to play with non std exhaust manifolds and or waste gates but if that what it takes do it .
Am running out of time and fingers here but also note another rule of thumb . The more blades and thickness of blade section a compressor wheel has the lower its pumping efficiency . Any extra work a turbine has to do shows up as lag or to use the correct term boost threshold , transient response suffers making the engine feel like a choked up torqueless dog .
chow A .
So i guess paying $2k locally is not so bad after all......
If you can get the turbo specs you are after. In the end if you pay $5,000 for a turbo, and are happy with it, does it matter anyway?
I don't think the compressor:turbine size "rule" is really that valid, considering the differences in flow amounts on various designs of wheels..e.g the T04E 57 trim wheel is the same physical size as a GT30R (HKS3037S) comp wheel yet the peak flows are more than 10 lbs/min different.
Disco-Thanks for your reply. I've given up trying to keep up with the different names everyone gives to the GT series.The turbo(s) I refer to are TO4S comp wheel (48 trim) ,flowing 44lbs/min,rated at 400hp and 440hp with 0.64 and 0.86A/R respectivly.So yes,it seems we're refering to the same unit.
Now I'm no turbo expert,but I'd like to discuss this. If this turbo is not built well,and requires high exhaust gas speeds/more revs to get it up on song,that's fair enough....But,wouldn't this just mean less use of the wastegate for control.I mean if it needs more shaft speed to work,the wastegate wouldn't need to start opening as early/by-passing as much gas,etc to limit shaft speed,so would this really matter? If anything,the requirment for higher shaft speeds to generate good boost would ensure that these turbo's would be efficient at high revs(?)
Also,the issue of exhaust housings/wheels being a restriction at high revs,and/or generating "detination friendly" egt's...surely this wouldn't be the case (at least) with the 0.86a/r housing...on say a 2.0L engine? or do you mean the actual turbine wheel creates too much turbulance at high speeds? or am I no where near it? :D
I notice that some "GT30"s use a TO4S comp wheel (56 trim) and 55lbs/min flow,with 0.82 (84 trim) exhaust and rated at 500hp.... still with a TO4S wheel? do these turbos share the same disadvantages you speak of as the "GT25"s?
And just to confuse things (well,me) further,there's a "GT25" that uses a GT35 comp wheel,flowing 44lbs/min-(same as the above mentioned 'bad' GT25) uses a 76 trim exhaust wheel( same as above too) and rated at 400hp????????? so that brings me back to the same question again.....can the TO4S wheels, (and thus equiped turbos) be that bad?
Thanks for your time
These GT30's you mention dont have it so bad because the larger (higher flowing turbine) is closer to the correct balence of exhaust gas flow vs compressor airflow . In a perfect turbo world your engine would have equal boost pressure and turbine inlet pressure (back pressure) across the cylinder head . This is difficult to achieve but the major advantage is beating exhaust gas reversion back into the cylinders when both (or all four) valves are open . When reversion happens (ie exhaust manifold pressure is higher than inlet manifold pressure) HOT spent gasses flow back into the cylinder to mix with the cooler inlet charge to pre heat it and polute it . The whole idea of efficient turbo compressors and intercoolers is to create airflow that is cool or dense which per unit volume gives a higher weight or mass of oxygen . If it gets pre heated again you've undone all the good work and are MUCH closer to piston crunching detonation . Spent exhaust gasses don't burn very well or contribute to power production either . Another downer is that if what power the engine developes is partially used to push the exhaust gasses out of the cylinder through restrictive manifolds/turbines/housings/exhaust pipes its less power to drive us down the road . The simplist way to look at it is forced induction tries to turn the engine into a larger capacity one with larger capacity exhaust flows .
Back to the "GT30" . The honest retailers will tell you that there about 19 or 20 different turbo's using that UHP 84 trim GT30 turbine . If your curious like me and spent months digging up turbine and compressor flow maps you also would have noticed that identical turbine and housing combinations show different efficiency levels depending on what compressor and cover are hanging off the other end of the shaft . I put the question to a Garrett production engineer (and petrol head) I know of in the US why ? He said large capacity compressor wheels need lots of shaft torque to drive , they have more bite into the air they screw through . If the work needed to drive the compressor is realistically more than the turbine wants to give you get exhaust gas slip losses through the turbine . So with the turbine turning slower than the exhaust gas wants to flow to get through it (all in a vain attemp to drive that great galoot of a compressor) the restriction sets in and turbine inlet pressure climbs . Remember I said the more and thicker blades a compressor wheel has the lower its efficiency . Well these things as well as outdated blade shapes give a TO4S wheel more bite (and resistance to turning) than later designs . Most of you will have noticed that propper GT turbos claim quite high power outputs for their size particularly when compared to old TO4's . With todays modern turbos a lot of effort has gone into reducing markedly the rotating innertia of the turbines and compressors so that less exhaust gas energy is required to accelerate them . Their open blade forms make them highly efficient at higher rpm's than the old dinosaurs so they don't need to be physically huge to move lots of air and flow lots of exhaust . Compact is good in overcrowded engine bays . So we have light weight bits that are easy to accelerate and pump efficiently with low exhaust gas restriction . I'm sure the annular contact ball bearings were put there purely because Garrett knew the old bush bearings and thrust plate could never survive the extra rpm's , not reliably .
I think the GT30/TSO4 was early in the days of the Garrett GTBB when most of the development was aimed at the turbine , later evolutions used superior compressors that pumped cooler air and required less shaft power to drive . They also work better at higher pressure ratios than earlier designs . Diesel engine designers are pushing for higher and higher boost all the time so compressor and turbine efficiency becomes more critical to the success of the package . Garrett has been developing better internals for turbos which should be appearing soon , first for diesels and eventually petrol engines .
Hope some of this helps A .
Cheers for the reply.Interesting stuff.So from what I can gather,the TO4S comp wheel equiped GT series turbos are not much better (if any) than an old school TO4? except with slightly better responce time,due to the ball bearing core. Or would that be negated by the comp/turbine inballance?
Pitty I bought my TO4S wheel'd turbo 4 years ago..... :rofl:
oh well
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
