  • Replies 113
Guest GR33DyMANGO
Yes, wheels world are agents for whiteline. They arnt in subi any more though, not sure where they are now. Nasty landlord wanted to raise the rent to an unreasonable amount so they have moved.
im going to set the story straight. i know the landlord.
the landlord did not want to increase their rent at all. they owe alot of money, which is mostly owed to the landlord in unpaid rent.
there are no winners. everyones lost out.
rob, can u please refrain from calling the landlord "nasty" until u know the real story. thanks.
i have nismo adjustable suspension all round in my car and am gonna take it to the drags soon, what would i need to set the rear on for optimum performance?? i am gathering that i would set it on the softest possible, to get the best traction, but im not entirely sure, can someone enlighten me on this???
GOT BOOST : you going down to the Motorplex this Wednesday?
I'm taking my video camera .... gonna get some nice footage! :P
My brother actually got you on video a couple of weeks ago dragging a Silvia!
Glad you won :D
u want a setup that doesn't bounce back up quickly after it squats. ie so the rear stays down allowing the tyres to grip better due to the weight being transfered towards the rear.
how u do that with adjustable suspension i have no idea but thats what your after.
I dont think you'll see an increase in power (maybe a better curve and maybe a couple of kw's). But with the better cooler the car will be getting more cool air in and intake temps will be better which will stop detonation. The next step is either bigger turbo and more boost, or (I would do this first) new ecu or rechip the r32 cpu.
Rob
Originally posted by rob77
power as in horsepower?? remember engage brain before opening mouth :)
Rob
sorry buddy, not sure what you're talking about - think you might have yourself in a twist :(
1.34 HP to every KW
kw = 1000W
watt=power
rootle tootle :D
if running stock turbo you might find your car runs worse.. not better when fitting the new cooler. You may need to get some tuning done?
That cooler may to big for you current application.
I fitted a 750X350X100 to my R33. Initially run like crap, it gave me lag... took sh*t load of tuning of AFC and adjusting timing to get it right. In the end the cooler increased my power by 10kw on the dyno.
To this day I believe the cooler was to big for my car.......
Dan
Guest GR33DyMANGO
hey imacul8 do u do weights, take supplements etc? i need some tips. i use creatine and take musashi p40 protein and do weights every 2nd day for 45mins. i started about 2months ago properly. any ideas how to get beefcake? am interested in seeing your pics imacul8:D
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
