nedb and GTS_DUY, its a standard GTSt with JUN 4 Door GTR Kit. It also sports an SR20DET.
As for the rear tail lights, they are from a coupe. if you wanna do a rear lights conversion drop me a pm, we have copied rear bars that allow you to fit coupe style tail lights and bootlit.
  • Replies 71
I nearly bought one from Queensland that was done by Skyline imports. It was black GTS4 R33, but had all the R33 GTR V-Spec gear including the pumped guards. They wanted $40k for it, I got it inspected and before I could put a deposit on it, someone from Dubbo bought it:rant: . The conversion was very well done, but it was not a real 4 door GTR. I looked at importing one and I could not get it for less than $75k onroad. This is because the did not have SEVS and needed to go through all the evidence crap. Even though they have the same driveline, the exhaust is dirrerent, so it would not pass. I think you would find that Edwardo's car has a yellow (pesonal import) compliance plate as it would not have passed under the new scheme. I also looked at a Stagea 260RS in Queensland and this car was $60k, but it is not the same as a REAL 4 door GTR.....I had to settle for a XR6 Turbo at the end of the day, but I would swap it in a heartbeat for that 4 door GTR:wassup:
Mine was imported under the old scheme. I saw the black one as well it was a very nice conversion. I have seen one other a silver 97 it ended up in SA. They only came in three colours. White, silver and purple (the one I really wanted).
It is amazing how many Skyline owners who stop and don't believe it is genuine ,until I let them inspect it.
Pics of the interior and under the bonnet, and the other two colours.
I've seen this car in the flesh. It's very nice ;)
I even took a very bad quality photo of it with my mobile :P
That is at Gavin's shop it is using a bit too much fuel.( I know it is a GTR) but one of the oxygen sensors is faulty I am waiting for one from Japan, and a Power FC.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
