Hi guys,
I have been making some minor changes to my ignition map as my tuner had it running way to much advance so I am cutting it down a bit. I have been using the map tracer to locate the areas on the map that are used and noticed that the tracer never goes passed cell 11 on the load/boost axis. I guess this is due to the AFM maxing out (am i on the right track?).
Any way my question is this:
Has anybody out there got some sort of conversion for the load axis...
i.e. a conversion for the p1, p2, p3, p4 on the load scale etc etc...
A conversion for the rpm would be good as well, i.e. n1, n2, n3
I realise that these are linear and that you probably dont need to know what PSI level they map to but it would be nice to have the info.
Sorry about the long topic...
https://www.sau.com.au/forums/topic/51683-pfc-map-x-y-axis/
hi, load on cell 11...seems low to me are you using std AFM? What about turboes? what boost are you running? Is it a GTR R33? All these can affect what cell you end up in at certian boost levels?
On my R32 GTR, std AFM's, highflowed GTR turboes, running 14psi I reach cell 15 on load by 3600rpm to give you an idea anyway. But remember that the AFM measure total airflow not boost (although thay are associated) and as I have larger comp/turb wheels my turbo may reach cell 15 at 14psi boost but yours may not if they are std GTR turboes.
That aside please answer the above questions first and maybe myself or other here will have a better chance of helping....
Mike
https://www.sau.com.au/forums/topic/51683-pfc-map-x-y-axis/#findComment-1022295
  • 7 months later...
Old post revive.
What I do find strange is my Rb30DET with the PFC ALWAYS dips to load point 19 at WOT on 12psi at 2000rpm. It holds load point 19 all the way through the rev range.
It did this on the RB20DET afm and now also the Z32 AFM.
The Z32 AFM didn't 'appear' to change the map trace at all. ?!? :)
Strange. Has any one else had experience with the before/ after map trace with the rb20/25/z32 afm?
https://www.sau.com.au/forums/topic/51683-pfc-map-x-y-axis/#findComment-1350433
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
