  • Replies 309
Okay.
Saturday Afternoon and I've performed the nessecary removing and refitting of the engine bay.
Had to remove all the stock intercooler hoses from the turbo to the front of the car and from the front of the car to the throttle body inlet casting.
Removed the compressor outlet ally casting and all bits. Took me about an hour to pull it down, and 5 minutes to do the welding!
Once all rebuilt, all was well.
I now have the jig for the R34. It's going to be hard to make the pipes as the BOV and PVC return pipes going to the rubber duct. So I'm going to have to get a bit creative!
Anyhoo, I'll post pictures on Monday morning when I can be buggered!
BASS OUT
I would be keen as well, if you can get some pic up that would be sweet. just quickly why do the R34 seem to have more of a prob with the intake piping sucking closed than anyone else. I dont think I have incured it but never had it on the dyno, but for sure metal intake pipe would flow better than the standard and I am hoping to run around 1.4 bar so I am guessing that stuff like that will become more critical at that stage. plus it looks cool.
Cefiro.
There will be two silcone sections on the hose. One at the turbo, one at the AFM.
10mm of air gap between them should allow sufficient flex.
TurboX.
Sorry I couldn't make it on Saturday, it took me a lot longer to pull my car apart and put it back together again!!
I'll organise something this week.
Hey guys.
Here are some pics of the pull down of my induction system to get the damn rubber pipe out.
I had to remove Air Box, both intercooler pipes, turbo compressor outlet casting, BOV return pipe, PCV return pipe and of course the rubber duct.
Once that was all out the way, I attached the pieces of steel pipe to the AFM and Turbo snout. Welded the bar in between and that's it.
Took me about 1 and a half haours to pull it apart because all the hoses and pipes had never been removed and were pretty damn tight, ten minutes to do the welding and then an hour to put it all back together. And not one single bolt was left over!!
Here are some pics.
Pic 1. shows how much was pulled down
Pic 2. shows the duct in position without the intercooler pipes
Pic 3. shows the Duct itself
Pic 4. shows the simple jig I made.
I hope this is of interest for you all.
BASS OUT
TurboX.
No worries, I have it at work in the city so drop in any time to pick it up between 9:30- 5:30.
Talking to my son who works every day testing turbo's and turbines he says that its important that the entry to the turbo is as straight as posible for as long as possible. Although on this pipe there is not much length and it needs to bend sharply its probably better to relocate the bov and vac inlets back from the turbo entry as far as possible while still retaining compatibility.
A big advantage of this mod is the smooth walls and air flow that will result from it into the turbo. The Std rubber unit with the folds etc. is bad for flow.
TurboX.
I would like to completly redesign the BOV and PCV entry points, but as you can see in the picture of the duct that I removed, it's quite complex.
As it is already, we will have to cut a section of the steel pipes from the PCV and BOV to make room for some Silicone hose to connect them.
Currently, the hose fits into a moulded part of the rubb duct. We are going to change it from a Male/Female connection, to a Male/Male connection using silicone hose.
Going to be interesting.
The only other option it to completly butcher the steel pipes from the PCV and BOV and run them into a smooth T configuration and that T into the Ally duct on an angle pointing towards the Turbo. Difficult.
I'm going to have make the Ally parts as close to stock as possible.
But for those who ant to get fancy, I can make the ally parts without the BOV and PVC bits fitted and you can do what you desire with them.
BASS OUT
The problem is not unique to the 34, most people don't even know about it because of the amount of boost you need to run before the problem presents itself.
I have heard older Skylines and Silvias have had this happen and even other non-Nissans, some backyard fix is to put wire like a coat hanger inside to prevent sucking in or collapsing under high boost NO THANKS! The problem is also accelerated by hotter under bonnet temps - perhaps due to copious drag runs or track racing. It's rubber, it flexes when it heats up!
I want to modify my pipe for better flow and to prevent it from happening at all - I don't think in the 2 years I have owned my car it has actually happened, although after 17 runs at Heathcote last year something may have...I couldn't actually say 100% that it was the pipe sucking in but it was a highly likely probability...
TurboX.
BASS OUT
Yes I agree, thats why I am happy for you do do all the hard work and I will just buy the finished product :)
I have already spent enough on custom alloy work like my Intake, etc.RB20Intake4_small.jpg:(http://www.turboclub.com/turbocars/nissan/.../GTS4/index.htm
Hey bass junky here is a pic of mine, should be the same as the R32 although no BOV pipe. I was just going to plug that one off and prob eventually get an oil catch can instead of recirculating it through j pipe, as I found a bit of oil residue in the intake pipe. lucky I took it off and had a perve as I found a restrictor in there as well. Doeas it look the same as the R32 (size etc)
here are some pics
Hey ceffy.
It's totally different.
Different ribs, looks to be a different shape and there is only one return pipe plumbed into.
I think this buy is going to be quite difficult.
well that means its a no no for me then unfortunatly, maybe I will buy a welder and some aluminium/ steel pipes and make my own at a cost of only about $1000 well worth it ha ha. The restrictor I dont know cant be doing any good in there spose I should rip it out. I think its only on cefiros and laurels rb20 to restrict power dont know why though.
    • Actually everyone on the roads was really well behaved. The only person that did any minor tailgating was a local hoon in a Turbo Focus. Unfortunately we weren't going the same way so there was no grand initial D touge battle. Lots of people pulled over and let me through. The amount of "Hey man nice car, omg skyline, nice 34 man woo" was suprising. Like really suprising. Like almost annoying. My partner was obviously surprised, she'd never seen anyone in the real world point out the car/like the car/want to chat about the car before, so to have like 3 people per day mention it was notable, I could finally say SEE? SOMEONE THINKS THEY'RE COOL. Everyone was also pretty suprised about the weather. Every day was dry and about ~13-14C. Mount Wellington had a sign that said they close the gates at 9pm and I was heading up there at about ~7:30. It was VERY apparent that conditions were getting significantly worse by the minute on the way up and down. The road on the mountain was terrible though, it's no driving road. I have various suspension related questions now. Luckily it was only about 20 minutes from where we were staying to the top of the mountain as said Google maps. We only had the 2 nights in Hobart. We went to the Farm Gate Market though which was really good - And went down to the Hastings Thermal springs/caves down there during the day. I'd definitely be up for going back again, so luckily there's a few more sights yet to see. Didn't get to do the west coast/queenstown/cradle mountain so this was supposed to be a 'scouting' trip anyway of sorts if I were to one day do/take part in/organize a more car-focused trip. As for the boat, it wasn't bad. Well it was bad, but not in the way you're thinking. We did the night trip which leaves at 6:45 (though you have to be there ~2 hours earlier) and arrives the next morning at about 6am. There is nothing to do on the ship. If you plan accordingly and bring a book/tablet/show to watch/charger you can just chill out, take some Travacalm and just sleep through it. The food there is an extremely basic buffet that costs $32 a plate, or $14 for a $3 pizza. The way back we had a travel kettle and a few different types of cup noodles and made our own tea/coffee in the room. This was a far superior way to do it. At the very least book one of the rooms with beds. I guess as we were in the off season we didn't have room mates. You get an option for rooms with 4 beds (2x bunks) or a room with just the two bottom beds. There's also some option for a deluxe queen bed but it's much pricer. We've been on sleeper trains in Asia before so we figured this is similar (and it was)
    • You just gotta be really, really, really clear and decisive with what you want your end product to be. 99% of people who want this conversion aren't "I want to run a 295 front tyre!" so they don't really need the widebody. They just want the OEM body to look a little less dumpy, so bonnet, bar, skirts job done with some camber, stretch, slam. It's when you want that, but then decide to pivot later you get big problems. See also if you're willing to get an all in one fibreglass bar, and you're willing to accept fibreglass problems like cracking the entire item on a driveway, instead of just a piece attached to the bottom, etc etc etc. Decide this all before buyin'.
    • After @Kinkstaah debacle, I'd never want to try and get it right 😛
    • The hood lines up with the fenders. The front bar doesn't perfectly line up with the fenders where the wheel arch is. You have to 'squeeze' the front bar 'in' as it wants to naturally flare out and be longer on the sides. There's a few threads where people notice this when they only swap a GTR style bumper and front bar. Unless you have genuine OEM items - you may be better served getting conversion kits. There are GTT bumpers to fit GTR hoods. There are GTR hoods (non genuine) to fit the GTT bracketry. MAY
