  • Replies 309
Thanks Redline.
They look very similar but there is an addition little bracket on mine.
I think the AFM outlet is also in a slightly different spot. Not by much , but by enough.
That's twice.
Just checked my account and again, it got returned to me.
Oh well, I'll put a tenner in the rubber duct when I send it back!
Cheers Mate.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
