In my 1)extreme boredom and 2)extremely lame attmept to get everyone to talk more, I have created this thread. The idea, obviously, is to post quotes, preferably car related but its not compulsory. Ones of a humerous nature would be much better than ones that come with realistic goal in mind :(...A fine example of this could be degrading the riced and rediculous.
https://www.sau.com.au/forums/topic/51764-quotes/
hehe had similar quote thing at work but they write it on whiteboard in lunch/kitchen room instead..
some quotes I can still remember:
"remind me not to heat up my salad in the microwave"
"I want to goto japan and see the snow monkeys"
dilbert quote:
"shut up and reboot, shut up and hang up."
https://www.sau.com.au/forums/topic/51764-quotes/#findComment-1022870
With strength comes limits.
Today, I will be running 4 bar.
I have 11,500rpm and I intend on using every last one of them.
What? The speedo only goes to 320?
Lights for beginners: Red = Stop. Green = Go. Amber = Go faster. Blue = Warp factor 10.
Objects in mirror no longer matter.
If in doubt, increase boost.
Engineered to be feared.
Insert smartass comment here.
If you start to see in B&W then you know your pulling enough G's.
Don't panic as you will black out soon.
I only use the brakes so I can accelerate all over again.
Please fasten your seatbelts and stow all your valuables prior to take off.
Drive it like you stole it.
Trust me, I got an E in physics!
Wastegates are for sissies.
When I grow up, I wanna be a mad scientist!
I am kept in place by G-forces, not seatbelts.
Revs, they're the #1 replacement for displacement
Do you have any idea how fast you were going ? Sorry Officer the speedo only goes to 320
You mean there is life outside of Internet? You're shittin' me!
I haven't seen daylight in six months.
Living in a cave with 47 computers and an Internet feed, located near a Dominoes pizza. See !d.
Living alone, get out once a week to buy food, no more than once a month to do laundry. All surfaces covered.
Will drift for food
If NISMO stands for Nissan Motorsports, does HOMO stand for Honda Motorsports?
https://www.sau.com.au/forums/topic/51764-quotes/#findComment-1024335
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
