Just got this funny email from some lawyer in Gana saying that someone with the same last name as me has died in gana and had 12.5 million dollars in a bank account at some gana bank and that they have not being able to find their next of kin, and they have found me as one of them :D
Apparantly i am entitled to 25% of the 12.5 million!!!!
I replied back to say yes i am a distant relative of this person and what i need to do next (I have never heard of the person they are talking about even tho i have the same last name). I am waiting for the scam part where i have to send them some money as a fee or something.
Has anyone else had this scam tried out on them?
https://www.sau.com.au/forums/topic/52062-i-am-apparantly-a-millioniare/
  • Replies 83
dude those scams have been around for ages... i cant remember the wesbite with all the ones that come from those parts of africa but theyre a pisser to read.
worst thing u could have done was answer them back.
I asked for a picture of the body so i could identify it :D
I am going to have some fun with this :P
just hong kong?
remember, this spam got to your inbox id|ot, and it didnt get blocked (flyng the captain obvious flag here)
If one can get through, so can more i think lol.
for a keyboard warrior you aint too smart
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
