  • Replies 50
Cefiros were made with drifting with the whole family in mind, hence its superior sideways performance with 4 doors.
JK
HAHAHAHAHHAHAHAHhahahhahahahhAHHAhhahahaha
family fun in an oblique brum!
check pm!
don't quote me on this Inark but I think in HPIv8 i'm pretty sure your cefiro is in there! if you have v8 watch the part after Ken Satoh's mate is battling the red RX7 at the start its the black ceffy which spins out looks like Ken's/Inarks only difference is I think when he sold it he changed the grill to the better looking type hence the one you have on now!
well if it is theres no stickers on it where there used to be... no wing on the back and the lights are different to... it does look identical tho a few people have said "HEY! THERES UR CAR!" lol
i dont think it is tho... could be :)
omg.
sorry to hear that nark.
I wish i knew someone that wanted/could afford/could drive that car fuuuuark....
i wish someone would buy it right now cause i found a cheaper dori car... an S13 silvia... as much as i hate them theyre a good learners car and i wouldnt mind if i stacked it lol u wont find it on prestige or jspec either... i dont think they look at this garage.
kei office height pitch/one off muffler/outlet/front pipe /GT-SS turbine /480cc injector /Z32 air flow /V1 air chestnut/bucket 2 /D-SBC/ imitation side step/imitation rear bumper/water temperature oil pressure gauge/brand-new strengthening clutch/カーツ 2WAYLSD/GT wing/outside item steering wheel/original CPU/ ロンシャン X4 book/over fender official recognition being completed /HKS prefix intercooler/square-hole headlight/xenon headlight attachment! !
yeah... there are stickers shadows on the window tint where the sun has faded the tint slightly and u can see the shape... but they could have been taken off at any time.
it is a definate possibility it could be it :)
you ever thought about selling that car to one of those performance magazines? like Drift Battle/HPI they could use it as a project car maybe even pull the expensive 26 out and place that RB24 engine they have (still haven't found a car yet if i'm not wrong) in the ceffy? or pitch the sale to someone like JMS etc who could use it as one of their promo cars or D1*Garage since they have ties with Ken himself would be fitting to go with their 180SX/S14 Strawberry faced drift cars? worth a try
or something like this i spose...
http://www.j-spec.com.au/list/index.php?ID=0948
Go for the One-Via... the front of a Sil is the ugliest thing ever, at least the 180 Front end makes it a bit nicer. :)
(No offence to anyone that has a Silvia)
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
