********The group buy will be going ahead in the next week, payments need to be in by Wednesday the 13th********
They're full Reverse Dials, they have the 2 tone colour. The colour can be flicked between green/blue and contrast can also be adjusted via a controller. They're similar to the ones on the attachment.
*******UPDATE ON PRICES*******
$140 per set, pick up available or extre $7 for next day delivery
Uniqueautosports sells the plain blue/green ones for $250 which are not reverse lights. It was hard to get a pic of them in the day, can't really see the lighting that well, but the attached file above is pretty much what you get, it looks exactly like that. At the moment I can only get them for the r33 and only up to 180km/h dials. I've asked them to try and make them for other models r32, r34 etc as well as 320km/h clusters, but they don't have them at the moment.
Thanks, Daz
https://www.sau.com.au/forums/topic/52210-r33-reverse-el-dials/
  • Replies 204
I've spoken to the supplier and he said we can do:
$160 per pair if we buy 10, or
$150 per pair if we can get can 20 buys
Hi Guys,
I would be really keen, but need to know:
what is the difference with reverse or not? I have seen the ones that uniqueauto has and they look way too bright.
the pic you attached is spot on with brightness... no too noticable from other cars and satellites....
Rob.
With reverse-lighting, the characters and marker lines light up (i.e like stock dials but with a funkier color!). With a normal backlit kit, the background lights up, but the characters and marker lines don't. They are a lot more common than the reverse ones (I haven't seen a reverse kit in the flesh yet) and IMO a tad too tacky.
JAGER: the dials that i can get are exactly as seen in the attachment..
yeah YOYO's spot on
the ones from unique are just the plain blue/green dials which are really quite bright, these are perfect I think, nice contrast in colours and not so boring
YOYO: I've asked about 180sx/s13 ones, but the only ones I can get for them are the normal green/blue illumicent ones. I really want the reverse ones for my 180 too but they don't make em. If you want I can get you those plain illumicent ones for a bit cheaper than these reverse dials
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
