I have just had a HKS Adjustable Exhaust cam gear fitted to my R33 Series II GTS-T 96 model.
ITs got a powerfc, full exhaust and split dump, pod filter, 11psi, and 10% mix of toluene.
My mechanic, very respected, (just got 300rwkw out of a VL turbo that day for an example just tuning it) put the cam gear in, and set it to 1,2,3,4 degrees retard, and 2,3,4 degrees advance, and every position the car lost power,
The only position the car made good power was at 0 degrees.
Anyone seen this before? I thought 4 degrees retard was supposed to make more power in the bottom end?
He's tuning the power FC and has managed to push it from 160rwkw to 180 so far, and like 2 hours
He says there is more to go yet
https://www.sau.com.au/forums/topic/52256-cam-gear-results-not-good/
I agree with Bass, I know it is obvious but you never know. The CAS is connected to the camshaft itself, not the camshaftpulley. It looks like the CAS is connected to the pulley but it's not. I have seen very experienced mechanics make this mistake. If you retard the camshaft 4 degrees, you retard the ignition timing 4 degrees. So everytime you adjust the cam timing you have to reset the igntion timing with a timing light.
If you have been watching and he hasn't used a timing light to check the ignition timing then that's your problem. :spcartman
Hope that is of some help.
so why does it work for some and not for others?I personally think there are gains to be had.I have never done it b4 only heard mixed emotions on it more postitive than negative.
Personally i think that there are gains to be had and if you go to someone or are that someone who knows what they are doing when it comes to this kind of tune they could prove it also.
Not to much longer b4 my theory is put into practice on my car.
seems like latter model s2 r33 and R34 seem to get less gains than the others.. few people have xperienced this in the past. Could be something to do with the slightly different VVT setup in the newer cars.
But there are plenty of older threads on it.
I am going to start another thread about it, but he left the cam gear at 0 degrees and went and tuned the powerFC.
Here are the results.
Sydneykid, I appreciate your input, and will most certainly let him know. He is a very very experienced mechanic, but hey, not everyone can know everything. I am sure he will love the information, and most certainly try it.
I love the world of free knowledge.
ok, I spoke to my mechanic thismorning, and he said that whenever he adjusted the cam gear, he reset the Base timing with a timing light, this guy is pretty on the ball even though he hasn't really done a cam gear before on a skyline. He didn't really know what to expect.
Maybe the Series II's have differenty VVT or something, and the power is already tehre, and just needs a PFC to tap into it?
He said it was very easy to get that power, but didn't want to go too much further because he didn't want to risk detonation.
I reckon thats awesome power for only 10.5 - 11psi, and its so smooth, doesn't hit hard, its like got heaps of torque from the word go.
Pull the hardest at about 5k though.
Awesome to drive now.
On my R34 they did buff fu(k nothing.
Cost me $600 in workshop and dyno time (At Hypertech) to find this out for all of you.
Check out this thread.
http://www.skylinesaustralia.com/forums/sh...light=Cam+Gears
Can anyone confirm that cam gears don't work on late model RB25's?
I was looking at fitting one to my S2
mine came back yesterday (R33 S2) and cam gear picked up extra kW most of the way thru with around 15kW at the top end. they work fine.
Thats a really good result, a couple of questions though.......
What cam gear did you get installed?
where did you get it installed and tuned?
You only need the exhaust cam gear right?
Cheers
Don't murder me but I'm pretty sure as the Rbs got newer, Nissan closed the lobe centres up. The early models ran very wide separation angles (Just like the VL turbo) but with newer models they closed them up gradually and increased overlap.
By what you guys are saying the gains are had by retarding the exhaust cam- is this right? If so then you are doing what nissan did with the later model hence less power increase because they have already moved them to a lesser extent.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
