Hi all,
I was thinking of buying a R33 non turbo 1995 or 96 model. What are the prices im looking at for a good condition one? Im thinking around the 15,000 mark?
And has anyone had experiance with them at all, like are they a good enough car and ok power. Im just 18 and i cant have a turbo car, so this seems like a good idea,
Thanks
https://www.sau.com.au/forums/topic/52689-r33-gts-non-turbo/
If you get one make sure it is manual no exceptions and you are only 18 so it is a very wise decision to go for non turbo.
Cheaper insurace and less hassles with turbos being made to go faster so you kill your self...........
People could say dont buy a GTS-t as they are slugs compared to GTR's but we dont, we dont drive GTR's because of cost to buy and insurance so use the same rule.
My girlfriend bought a series 2 NA auto R33... excelent condition, for 18k about a year ago.... its a very reliably car, probably about the same speed as say a holden 3.8ltre v6 (VR/VS/VT etc..) so not SLOW but not super quick...
Only thing she has spent money on is service every 5-10k 50-100$, petrol, insurance and rego...
good idea not going for a turbo car, they cost too much to maintain/mod and insurance is a killer
i got a na 33. i rekon you'll get bored of it hey. Drivin around in it looks good, but u do tend to get alotta WRX's+ other lines+ silvias+ 180sx, just abt any other sports car, wantin to drag. I got bored of my in abt 2 months. Its a great car to start with but i wouldnt be surprised if u start lookin into a turbo a couple of months after.
again... very reliable car and you should have no problems. Not uber quick, but neither are most things around that price level. 145kw isn't anything to be sneezed out, but I guess as all cars get more and more powerful over the years can start looking a bit slower in comparison. The weight will be the same as any commodore, camry, or magna out there - and that is really what you should be comparing it against. It has the sporty looks, but the practicality of many of those other cars.
I would say actually $15k is the upper end, as there is not massive demand you can get a goodie for around $12k these days.
My mate got a manual GTS4 for $14k and that was about the only car that actually looked to have a *genuine* 70,000km on it or so (no scratches, no wears in any of the trims, etc). No problems whatsoever and he is very happy with it.
you'd be better off buying a turbo in the first place. could always just turn the boost right down and pretend it's an na :)
and aren't all gts4's turbos? rb20det's...
as said above the gts are to be compared with falcons, commodores etc. on performance... however the skyline looks 100x better :)
get a Silvia really fun car
I think u cound b ok with a Turbo Silvia 2L Sr20 or get a non turbo like me As for insurances it bullshit non turbos save u money i got Quotes on Silvia Q non turbo and Silvia K Turbo differents was $30
Insurances is HIGH CAUSE it is a IMPORTED CAR not that it is Turbo
I love Sr20's there sick as I have a Mate Selling a Silvia Q club if u want me to give u his MSN or number PM me it really well looked after he just Droped a New Motor in it Same as my one Just Blue not Silver
If you are going for a NA, make sure you get a GTS25 and not the GTS, the 25 has the 2.5L RB25DE engine, 147kw/~200hp whereas the GTS has the RB20E with 100kw/~130hp of SOHC 2L power!
The GTS is very underpowered for the weight of the car, but the GTS25 is about on par with 6cyl Commodores (~150kw from memory) and is lighter.
The R33 GTS4 is essentially a GTS25 with 4wd, but a bit less power at the wheels due to drive train losses.
are the gts models eligible for import? i thought they fell under the power to weight ratio allowed by dotars.
therefore all the non turbo r33's you see driving round are rb25de's
get a gts4 then when you get bored of the N/A you can drop an rb26 into it for some awd tt fun :cheers::D;)
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
