coming home from work
got pulled over on king georges road
my front tyres were worn on the inside, which i never checked. stupid me.
so $78 for fine + new tyres + pink slip
lucky me :Bang:
cop said he wouldnt look over the rest of the car
ahh well i reckon if it wasnt the tyres he would have found something else wrong
https://www.sau.com.au/forums/topic/52697-my-first-defect/
If you drive a performance car they always pick on you and ask you about people youv'e never heard of before, then RBT you and look around your ride.
Never happened when I had my commondoor!!! I wonder why!!!
https://www.sau.com.au/forums/topic/52697-my-first-defect/#findComment-1036679
thats what happened the first time i was pulled over for no reason (other time there was a reason) - think its just to check anything outstanding, then he came back with rbt (didnt check the car) and after i blew 0.00 (presumably) i was on my way
https://www.sau.com.au/forums/topic/52697-my-first-defect/#findComment-1038214
Sometime it's best to stay in the car and act meek.
Ask if you can get out of the car and just have a chat - there's gonna be that 5% who are just not personable and well... you get that.
But I've been done bad (ie. 30 over) and the officer was polite, charming, even apologetic and you know what... they're people too.
T.
https://www.sau.com.au/forums/topic/52697-my-first-defect/#findComment-1039284
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
