well i've had a couple coilpacks die recently and a couple people telling me the setup on the rb motors are prone to failure due to copping all the heat from the engine and dont generate a very strong spark. so i've started considering alternative spark setups.
has anyone had much experiance in using different coilpack setups with the standard ECU? such as using external camira/bosch coils and leads and setting it up as a wasted spark system?
https://www.sau.com.au/forums/topic/52754-alternatives-to-standard-coilpacks/
I agree with Joel, our R32 GTST has 170,000 k's on the original coil packs, the GTR has 142,000 on the original coil packs, the Stagea has 102,000k's on the original coil packs. The old R32 GTR still had its original coil packs and it is close to 200,000 k's now.
Personally, I haven't had a problem :(
My standard coils were working fine, but with higher horsepower applications then the SplitFires are the way to go:D Series II GTS-t coils are pretty crap though, as they have the modules inbuilt, and are much more prone to problems.
I left the the R34 GTT of the original list because it hasn't done that many k's. It has 265 rwkw and it's coils packs are std, maybe I am just lucky with them.
On the race cars we use a Motec CDI with Mercury outboard coils packs, because they are designed to work with CDI's multiple discharge.
To avoid coil pack failure I took the upper belt cover off and used a hole saw and file to make a tear drop shaped opening to the cam belt area. I then opened up the little ventilation fins in the rear section ( fins vent into the coil pack area / valley ) so I now have air flowing through from the outer most part of the fan, through the hole I made, between the cam pulleys, through the fins and down the valley taking some heat away from the coils then venting at the rear of the valley cover. ( Hope all that makes sense ).
Should work on any RB I would guess.
I've yet to finish the job off with a nice piece of mesh to stop any nasties getting in but it seems to have worked as I've never lost a coil pack in my R32.
As Ed said my ones died ~80,000Ks back when it was N/A and only proved annoying at idle, when the turbo went on at 110,000K's it was all too noticable....the current R33 ones I'm using seem to be OK though (fingers crossed)
I did actually consider setting the packs up in a corner of the engine bay with spark leads going to the cylinders.
From what I've heard, the splitfires are the go.
There was an R31 with a worked RB20 I saw after the Drift Nationals with 6 older style cylindrical ones on a plate on the firewall with leads to the plugs. Not sure about the electronics behind the set up unfortunately..
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
