  • Replies 46
nevertheless ... its a fast car  :D
Oh absolutely, but as DB said it is not simply a big engine in an otherwise standard Supra. It has had considerable development and investment in both time and money. :D
hmmm ..somehow i dont think that run is qutie "true"
Yeh... I'm with you Butler! Definately a fake. A bit like those UFO sighting vids ha!
:jk:
SK.. for us less fortunate could you translate that in english :D
Either way, that's very impressive. But I guess like most things technical, we will never know the secrets to that car.
Hi guys,
I read an article on on Fast fours, the article came out may 2004, but this supra made 7.7 @ 176mph and they're expecting 7.2 pass. There are lot of supras making that time ljstt mentioned in the US (msp supra 8.3 @168mph no nos, Titan supra 8.7 @169 mph Street tyre, mvp unibody supra 8.8 @167mph).
Don't be thinking this car is some backyard throw together (like my cars), it's been racing for a few years. The US has a larger and more advanced drag racing market, Titan proved how much quicker you can go with an auto on their car (dropped .3 seconds(?) from mid 8's to low 8's).
The turbo is going to be the dictator with regards to horsepower, I think this car is meant to have one of the Turbonetics Thumper's on it (up to 2,000hp).
Check out the engine bay of the Titan car, notice the Wiggins clamps on the water + turbo lines ($US200+ each). That's a fair bit more "advanced" than Mario's car....
Damn that is a BiG F'Off turbo - look at the size of the exhaust housing - it's nearly bigger than the compressor housing - that is TOP END power !
BFGoodrich Comp T/A's are radial tyres - specially constructed and in this case, large creasable sidewall....
AWESOME tyres.....  IMHO, they shit on Nittos.
Adrian
fair enough. im not doubting the cars potential just that using radial tyres a pass so fast just doesnt seem possible at this point. considering it took the HKS supra which uses biggggg drag slicks to get as far as it has, it seems hard to believe to see a supra with radial tyres runnin almost as fast
The fastest "street" car on drag radials is a twin turbo'd 7 liter 89 Camaro.. on a 295 sized tyre it did 7.66 @ 186 MPH.
There's been alot of development on drag radials in the last few years, M+H have a new range out that is meant to be the same compound rubber as the drag slick. The lineup goes from Nitto (hardest), BFG, M/T then M+H (softest).
The MSP supra was on BF's since they sponsor the import series there, the Camaro was on M/T tyres..
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
