if any one has the 100v 2 pin plug in there stagea ...hullo prank...i have this interesting piece of kit that came in the back of the 260 but i think the guy has taken inverter with him
its a kenwood super woofer...looks like a smoke machine or some kind of rocket launcher
3 switches on back ..phase(norm or rev),omni position,turnover
3 lights ,60/90/120 hz
volume dial
on the front just says 100v 35w 50-60hz
is a heavy mofo ..really don`t know what it is worth ...can anyone tell me??
https://www.sau.com.au/forums/topic/52950-100v-inverter/
Jake, that looks a lot (if not exactly) like a HOME subwoofer that Kenwood released many moons ago, IIRC...
Maybe it's an added bonus from the last owner when the car was sold and sent from Japan!?!?!
Couldn't tell you what it was worth, though, sorry. Maybe you could get the model/part number off it and Google it, and then have a look on e-bay as well.
Nick T.
https://www.sau.com.au/forums/topic/52950-100v-inverter/#findComment-1041462
Nick T.
yeah its a sinister looking piece of gear...i`m thinking i could get good money if i listed it on e-bay IRAQ.....with the right ammo it could take out tank...
https://www.sau.com.au/forums/topic/52950-100v-inverter/#findComment-1043076
i have option catalog ..DAYZ...piture of rear power point in console with laptop /keyboard plugged in to it ..scanner has issues so cannot post pic atm
i know where there is a sic subwoofer that will run of it and i suppose any jap 100v equipment
will also
https://www.sau.com.au/forums/topic/52950-100v-inverter/#findComment-1044081
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
