  • Replies 176
Those are the boards we use for the S14 and work well.
Expensive when bought in small amounts so the group buy will be a good thing.
How is this going and how many more do we need to sell for a cheap price.
We may get a few to help with price purchase. Have you got the address table yet?
Cheers
Ken
Yeah, these boards work in a few cars.
I bought them from Grid Japan and will be contacting them about a discount once I have got mine in the car and working so that you guys won't have a board doing nothing.
Have not had time to pull the BIN file from my car yet :(
ecl,
The main benefits on a stock 34 will be the ability to raise the boost cut threshold, remove the speed limiter, and retune the factory maps to suit australian fuel and conditions, typical gains on standard boost just with tuning are around 10 rwkw.
Doc.
  • 3 weeks later...
  • 1 month later...
I am interested but need more info on the tuning as I don't know if anyone in Cairns could tune it and would a control handpiece like the Power FC be needed?
Sorry about my ignorance but this is all new to me.
My Stagea is currently standard but soon due a 3inch turbo back exhaust. FMIC and Turbo upgrade.
Hi guys,
Sorry for the late reply.
Finally managed to pull the ROM file from the stock ECU (thanks 666DAN & also DUMHEAD from silviansw.com).
Now all we need is the address file for the rom or try to crack it.
Yes this board will, according to GRiD Japan, work with S14/15/ER34(RWD, 25T)/U12/C34.
I do not have the rom files for the S14/15/U12/C34 though.
I've attached the ER34 manual BIN file I pulled from the stock ECU.
Ed,
Will you still be able to get me one of these? I can help out in locating the address maps. However it is going to be impossible unless we have different binary files to compare with.
Try extracting the Auto one and see the difference. Fuel maps should diff?
Ben, do you have a laptop with 9 pin serial?
The cable needs 9 pin serial to work.
Then we can pull the 34 GTT auto maps.
Give me a buzz.
Ricky, I've put up the manual map's. See if you can crack it ;)
So far when I apply the ECR33 address table to the 34 BIN the only thing that is the same is the rev limiter.
7050 rpm.
the badbiki daughterboard pictured wont work with other R33/R34 (non ER34) ecus which have a Hitachi H8 chip. these need a special daughterboard which houses the H8 chip and decoder circuitry.
i am able to disassemble and create address files from binary images (things like K constant, RPM and speed cuts if not in the rom editor ADR files are a bit more tricky but not impossible)
that one posted i see maps around 1200- 2800. the VQ is 1200-127F
what is the main chip number on the ER34 ecu? ie what type of CPU
yikes that was quick. yeah i need the numbers (top row) on the big chip of the ecu to do the disassembly. you can see on the second pic there are a row of holes which you solder the daughterboard to
I knew there had to be a good reason why I was stock-piling these bloody R34 ECU's :D
OK the big chip says: LM702D01J
Pretty sure that's it, as it's hard to read
Other printed lines read-
A12-212 750
816B100
the A12 number is the JECS identifcation code. the bottom number would be serial number
the top one. LM = manufacturer code of which there are about 20 listed for LM on chipdir. i think it is probably Hitachi as most Nissan ecus are but could be anything. SR20 ecus are badged JECS but are Mitsubishi chips for example
how accurate are those digits? i know they get hard to read. best with magnifying class under fluro light at some wierd angle to read the writing properly. at worst wont if i cant get it disassembled wont get constants (rpm, k const, speed limit) only tables/maps from doing a rom compare
I'm 99% sure....I did grab the fluoro and magnifying glass :rofl:
The chip also has that "UJ" logo that's in the centre of the circuit board printed on it.
Whoops just figured it...Unisia Jecs! So it's a Hitachi chip
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
