I'm not sure if anyone else has seen this, but Greenline have a list of 4 different suspension setups designed for Stagea. Here's the page, they start from AU$2000 down to AU$900. check it out guys if you haven't already. looks like i'll be giving these guys a call in the near future.
http://www.greenline.jp/catalogue/bccatpar...gory=suspension
Spoke to Heasmans, very helpful dudes
It seems that there are "genuine" Bilsteins for the Stagea, that Bilstein put in their catalog
ie
Front B46-2590
Rear B46-2589
but these are harder to get, and are a bit softer
the others that fit, are bit firmer and easily in stock are
R33 GTR front (B46-2107)
GTST Rears (B46-1916)
Hope this helps people
PS I spoke to Travers Wood at Bilstein Racing, free plug, good guy
What sort of prices would be attached to the Bilsteins?
email to [email protected]
but he quoted F $627 & R $453, which is about $300 cheaper than the
quote i got on the konis (tell him I sent you :)
They will also machine in the grooves for the C Clips for $15/groove (I assume that
means $60 for the set).
Wow Michael - I reckon that info is the best Stagea info on the forums yet! SK let us in on grooving the bilsteins to lower ride height using stock springs - but when i checked with my insurance company they said self-machined grooves would void any claim where the car was in motion as suspension is considered a critical component and any non-manufactured shock absorber changes would void a claim instantly (like bald tyres). BUT if they are done by Bilstein themselves then this would get around that problem! THANKS
:P
:P
Your kidding right? How the hell would an insurance assessor be able to tell who machined the grooves? He wouldn't even be able to see them unless pulled the shocks out. And they sure as hell don't do that, they aren't allowed to "work" on the car. You could mount the same argument with the nuts that hold the shocks in, were they done up by Bilstein? Then there is the wheel nut argument? Circlips, bolts, nuts, screws they are all fasteners, so the same rules apply.
:cheers:
I am with SK on this one, but of course if you lower the car 4 inches and have 5 degrees of negative camber on the rears, dont expect anybody to cover you, it wouldn't matter who did the machining on the shocks.
Like all insurance stuff, full disclosure is the safest (they will use ANY EXCUSE to get out of paying). I would have thought that a mod that is done by a suitably qualified person and still is able to get a RWC is ok.
I shopped around for insurance for a while and got a pretty good deal with Just Cars. NONE of the "normal insurance " companies (AAMI, RACV etc...) would touch a grey import anyway. So just talk to them. There is no doubt that ANY MODs will give a increase in premium, but as long as they are legal and if needed engineered, it should be ok. Thats just life with modded cars and "esoterica".
cheers
Hmmm - maybe this guy was having me on - but he seemed pretty sure - like hed had the query before - talked alot about how 'doing it yourself' you may compromise the shock by grooving too deep etc. He said there were only a few critical insurance voiders in motion crashes - including non-legal tyre wear etc - and also shock absorbers - one of those things in your insurance 'full' contract - all that fine print you sign off on where it says stuff like "I declare that the vehicle has roadworthy tyres and dadada and understand that not having roadworthy tyres or parts used other than as the manufacturer intended dadada will void any associated claim for ...." Of course he said if you rear end someone and have $2000 of front bumper work no assessor is going to check your shocks and ask about your circlip grooves! lol BUT he said if you happened to wipe out another car and a family then they'll be going over the wreck with a fine-tooth comb to find blame... so yeah when they find modified shock absorbers that is against the conditions of insurance (that bloody fine print long 20 page booklet) and your signed declaration was misleading therefore voiding your policy. However if you can prove they were manufacturer intended modifications (ie they did it and you can prove it eg receipt) to the shocks then you are ok.
Anyway - could all be some guys version of having fun at work and making life hard for me - but i WILL dig out the insurance terms and conditions booklet and go over the fine print... not that itll matter now that Bilstein machine the circlip grooves themselves. Eitehr way - id love to prove the guy wrong - but to save any doubts it great to know Bilstein do it anyways.
:P
Another suspension option with specific fitment for Stageas has been added to the Nengun site... ZEAL coilovers... dont know much about them - in fact never heard of them... but another option none-the-less for anyone with with a spare $2200 :)
http://www.nengun.com/catalogue/product/384
It states the spring rate - but I have no clue about interpreting spring rates... maybe SK can put it into laymans terms as to what sort of ride thats likely to give??
Oh yeah - and they're yellow - will match my Stag woohoo lol
They state 7/6 which is 7 kg / mm (390 lbs per inch) for the front and 6 kg / mm for the rear (335 lbs per inch). As a comparison, the standard Stagea fronts are 165 lbs per inch, so that's a 137% increase in spring rate. Usually for sporty road use I would be loooking for around 30% increase. I think I'll leave it at that, you can make your own judgement from the numbers:cheers:
OK - so a dam hard ride LOL :D
Hard is not good on Ausie roads. The Teni's in mine are way to hard. I bounce and bang around on every bump, get air bourn on bigger bumps and almost get thrown off the road on mid corner bumps.
I had trouble keeping up with an old Patrol on a narrow windy bumpy road today and felt like I was going to be pinged of the road a few times.
(The Patrol was flying and getting loose on almost every corner)
The first thing I will be doing when I sell my Skyline is putting in a set of Bilstines with GTR front springs and specially wound Whiteline springs for the rear
  • 4 weeks later...
I keep forgetting to post it up, the rear spring rate is 170 lbs per inch. As previously posted the front is 165 lbs per inch. Considering the weight carrying capacity of a waggon, that's not surprising.:D
Hey guys, i got my suspension i ordered through nengun today, the TEIN type wagon. only problem was when i opened the box, there were only 3 shock absorbers, the 2 fronts and only 1 rear.
I think this is a funny sort of suspension kit, considering what i paid for it.
as soon as they send me the other shock absorber i'll let you guys know how it fits, for now here's a pic of the 3 i have.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
