Its not as short as the s14 by the company im getting.
this stagea will be lower than any one on this board, and mnost skylines. it takes extremes and enginuity to do it
A 3.25" exhaust will touch the ground under the rear subframe before you need shorter rear shocks.
If you use a shorter shock, how are you going to get around the lower spring seat clearance to tyre problem?
:D cheers :D
because he can i spose...
solve your problems all at once...remove the shocks all together :D You'll have about as much manouvreability and it's half the cost :D
Why not just get larger side skirts if you want it to look lower...the lowering you are doing now can't be helping the handling much at all past a point
jesus, no wonder people talk crap about aussie style (not me)
I can build stupidly radical cars and daily drive them
I need shorter FRONT SHOCKs not rear
and i dont need to worry about my wheel to shock clearance, because with a breath of intelligence, Im going to run more htan a 18x8 +30 offset.
try a 19x9 +20 offset.
no need for inner clearance worry.
honestly guys, not to be mean, i havent seen one stagea on here even trying what i am doing, just a bunch of people sayign things are unsafe, and stuff.
I know what is safe, i know whtas not.
With 19s, i will have to go lower to look as low as i want. becuase i have almost an inch and a half more of wheel and rubber combined from a 17inch setup like i have now.
and hte exhaust im fabricating wont even hang below the frame rail. even at 3.5 inches
Yall are trying to tell me things like i have no clue what im talking about lol
Edited by yokotas13
:domokun::rant:
go for it dude, interested in the outcome
dont be offended by the comments, ive been to japan and ive seen first hand just how radical the sorts of modifications that are made to cars, however in australia we have a legal clearance limit of 100mm, and police that are very swift and firm when it comes to defecting our cars off the road.
Maybe they DO have a clue!
And you do realise that this is SkylinesAUSTRALIA, so like it was mentioned, we have rules and regulations that we have to abide by, and the police generally aren't too keen on modified cars, especially so if it's an import you're driving... Not to mention the crappy roads that most of us are subjected to here, so we have to make a compromise between drivability and performance.
I'm lucky in the sense that my car is still standard, who knows if I'll start attracting negative cop action when I have the suspension sorted and some nice wheels on it.
i understand that.
So if you havent done the stuff i am doing, then you have no firsthand experience on if it is safe, if it will work, or how to do it.
SO its all hearsay and i read it in a magazine or X person told me this.
Im telling you first hand, it will work, and be safe, and with the arms i have/getting the suspension geometry will still be there, and i will still have adequate suspension travel for the track.
suspension is one thing i can actually do right
1. I need shorter FRONT SHOCKs not rear
2. and i dont need to worry about my wheel to shock clearance, because with a breath of intelligence, Im going to run more htan a 18x8 +30 offset.
3. With 19s, i will have to go lower to look as low as i want. becuase i have almost an inch and a half more of wheel and rubber combined from a 17inch setup like i have now.
4. and hte exhaust im fabricating wont even hang below the frame rail. even at 3.5 inches
Sounds like an interesting project, I would like some more information if that's OK;
1. Didn't you say you were using S14 rear shocks because they were shorter?
2. Are you are going to flare the guards? I didn't think that 9 x 20 mm offset would clear the standard guards?
3. Are you running a lower rolling diameter tyre? Rim diameter is IRRELEVANT, most people run the same (or similar) overall wheel/tyre diameter to avoid excessive speedo error, what are you doing to correct that?
4. Are you going to cut a hole in the rear subframe? Whereabouts?
5. What are you doing with the exhaust system where it goes under the LHS rear drive shaft?
6. What are you doing about the excessive drive shaft angles? Front and rear?
7. What are you doing about dynamic camber change? Front and Rear?
8. What are you doing about bump steer? Front and rear?
:P cheers :P
:happy: cheers :laugh:
1. Not the actual OEM shock, the coilover shock they use for the s14 rear, is shorter than the GTR front. so it allows me more vertical adjustment. it wil be revalved to match the spring rate i decide on.
2. Yes, i have a fender roller on teh way. I have to roll the lip on all 4, and i will be pulling the front about 10-15mm and the rear only 5-10 due to the rear door to fender space there will be a 10 +20mm on the rear
3. Nope, not worried about the 1.y6u843968493207689342% speedo deflection. up to 10km over is acceptable in japan. not a huge deal. I have a second set of wheels (the stock 17s) for Inspection purposes
4. why would i need to? havent seen a problem yet
5.I am going to redo the exhaust when needed (once i order the new one though). maybe run a dual pipe so i can run two smaller ones in that area where it dips. havent exactly decided on what i want to do
6. There is enough play without binding for driveshafts. they have an extreme amount of angle they can take relative to what im doing without binding.
7.I already have rear camber arms, fronts are on the way
8. Tension rods moving the wheels forward should eliminate most of it.
Sydneykid is like a cat playing with a mouse
if he can get me a suspension system that will do what i want it to do. ill be more than happy to oblidge
but for now, im doing what i have to , to get the look i want.
not saying it wil perform well at that height, but i want it that low
Thanks for the response, I have a few suggestions/comments;
1. So you are going to use an S14 rear shock on the front of a Stagea? What are you doing about the shock valving requirements OTHER than spring rate? Stabiliser bar rate, unsprung weight, leverage and movement rates, travel limitations etc
2. I thought that would be necessary
3. Why not buy the right diameter tyres? Surely that is more logical
4. You will
5. Yep, you could do that
6. What about the horsepower loss due to missaligned CV's? Plus the greatly accelerated wear?
7. They will fix the static camber, what are you doing about the dynamic camber change?
8. No it won't, you will need to correct the geometry of the steering arms to align with the lower control arms.
There are no off the shelf solutions I have seen for #1, #4, #6. #7 and #8, you will either have to design and make them yourself or have someone who knows about suspension geometry make them for you. Metal fabrication skills, suspension geometry simulation software, welding skills, a good understanding of shock absorber hydraulic engineering etc, will all be necessary.
As I said, it's an interesting project, I just hope that you have a full understanding of the hurdles you are facing and the budget that will be required to overcome those hurdles.
:( cheers :laugh:
4. You will
:) cheers :)
1. as i already stated they would be revalved. But im looking into a few other options. a local coilover company has a stagea application with an optional 30mm shorter shock. so it might solve my problems
3.you cant get at the heights i want for show with correct diamete tires. however at the track i will be running 17x9 +30 all around with i believe (dont quote me i still haev to make sure its the right size) 255/45 Advan Reo1rs.
6.gt25 or 27 will have plenty of help with that this summer. and on the wear, ill just get some extras. they are like 20 bucks a piece.
7. I wont go to the track at that height. bumpstrips would rip my car apart. this is only show off height and DD height.
8. We shall see what happens. It got rid of the bumpsteer on my 180sx.
regardless, when it matters, the car will be at a reasonable height correcting all geometry issues.
So the idea is to have it at a low height for shows and then a more sensible height for actually driving?
:P cheers :D
oh no,
low for DD, and raise for the track.
"DD" is that Daily Driving?
Since you are going to set it at an appropriate height for track work, you obviously know how bad it is going to be, everyday, for handling, accelerating and braking. You are doing it simply for the low look, because EVERYTHING else is negatively affected in order to achieve that one thing.
There is nothing wrong with that, as long as you accept the compromises that it causes. Don't try and fool yourself or anyone else reading this thread. Looking back on your "it wil be safe" comment, the truth is it will be SAFER (and faster) when you "raise it for the track".
:D cheers :P
Of course it swill be SAFER at a track height
But at the height it is at now. i dont buttom out, i dont scrape
on entrances into some places the wheel rubs the coilover. gotta fix that
But the truth is, to be an innovator it takes work.
People could argue a TV in a car isnt safe. But its legal in jpan, not in the US and there are less accidents in japan than the US.
but i dont expect to be racing around town at the height im at. Just cruising.
But it is safe
but actually
at the height it is at now. which it will stay at becuase, well the tires get in the way fo going lower, its at a perfect height.
Edited by yokotas13
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
