i am looking at the hks hiper damper kits. The seller has told me that the R32 one won't fit, but that the R34 one will. They are second hand on eBay but they look in pretty good nick, say they have no leaks and the seller has a good rep.
Is the seller right about the R34 ones being suitable for my stag?
You are better off looking for a Stagea kit. There is so much more glass & steel behind the rear wheels on the wagon, even if they do fit (all depends on model) the spring and damper rates at the rear will be for a car that weighs 300kg (approx) less.
Ebay sellers will often tell you what you want to hear, to make a sale. Buyer beware!
Edited by Daleo
Cool. I had wondered about the extra weight, and a seller wanting to make a sale, which was why I thought I'd ask on here. Thanks for the help!
No worries, this forum has saved me plenty of money . :thumbsup:
Unsure of your budget, but maybe have a look at BC coilovers. Excellent value for money.
I'd been looking at BC, but am not sure how much budget I'll have left after putting a Nismo chip in it, plus exhaust, but I'll see how I go. I was just so tempted when I saw the HKS ones so cheap!
Hi after reading the whole 43 pages of this thread, im still unsure wether the R32 GTR shocks on the front and R33 GTST on the rear will be suitable to the weight of the stagea or not? I know there not perfect but will they be okay?
If anyone can tell me if they have used shocks from the 32 and 33 and how they went, it would be great.
Cheers
yep gtr (or gtst) front will fit & r33 gtst rear will fit with a bit of work (rear top hats are different)! As for spring and shock rates, if you are using adj coilovers then it wont be a problem, but stock items wont be perfect, but are still quite usable!
* only the factory fitted manuals (ie: 260rs & rs4s) use the gtr style rear fork!
Edited by Zorro
So what to do... after having the stagea lowered I am now faced with a choice... continue to replace the castor and camber bushes every 20 000 kms... or raise it... :(
But it is sooooo pretty this low!!!And I want more aggressive castor.. not less!
seriously...how much worse are uni-jointed castor arms tna bushes... I know they make noise when wet but is it really worth being concerned about...?
and and what is the minimum height I should cut my bumpstops???
*end rant*
@captinsane, what brand bushes are you using? you could use those pillow ball/solid mount/uni joint/shiney metal style adjustors but they require more maintainence (cleaning and re-lubricating etc)
also any modification to the bumpstop is illegal in any state so if you need to pass a rego slip soon i wouldnt unless you go spares. dont get me wrong my vw touches the ground with no bumpstops so i love lowered cars but yeh id either pull em out or find some GTR ones to cut.
Hi guys , i've got myself a s2 RS-v rwd 98 wgc34, an i have got myself some ISC coilovers but the fronts dont fit. the cars top mount has 3 bolts an the base mount is the same as a holden mcpherson strut, the guys at isc r not to sure whats going on. can anyone help? the stub axel has a lower control arm, tension arm, sway bar and the shocky. help.
I also have a 99 RS stag that I am hunting shocks for. Don't know if to go cheap BC coilovers or a Bilstein or kyb shock? I really want a nice comfortable ride and a guard height of about 360 ish.
Any experiences?
Cheers
Any experiences?
Cheers
i've been running BC's for just over a year now and i'm happy with them, i haven't had any issue's. the guys at justjap recommended them to me and said they had a few customers running them in their stagea's and had only good reports about them. from memory the springs are only a bit stiffer than stock, something like 8kg front and 6kg rear. i only have the dampers set to half way and the ride is good. i do a few road trips a year, sometimes with the car fully loaded, and with the exception of a few bumps that would be harsh on any suspension, the ride is comfortable. i've taken the stagea on a couple of twisty mountain runs too and it handled really well.
just got a 97 stagea rs4 and my rear wheels are sticking out a mm or 2 and i need to get stock rims for it or does anyone know what stock rims can go on stageas like r34 maybe r33 etc
do you have plans to lower your car? when you lower it the wheels will pull in a bit and wont stick out as far.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
