hey y'all,
was out last night givin my 'line the beatin of its life.
the engine was so close to being ***d im not surprised it
blew in spectacular fashion. F****en fan snapped off at the water pump
and came off all together smashing alotta parts in there.
Just wanna know wat a good price would be to pay for a rb25de
with less then 50000km. is there anyway to make sure they are real km??
im in perth so if anyone knows of any places, it would be appreciated.
thanx guys
https://www.sau.com.au/forums/topic/53140-rb25de-pricing/
The NEO is what is found in the R34 skylines...it's the newer version of the RB25 found in the R33...makes slightly more power...and the fact that they are made from late 1998-2001 mean they are more likely to be in better condition.
https://www.sau.com.au/forums/topic/53140-rb25de-pricing/#findComment-1044146
hrmmmm, after much thought, im glad to say im gonna go the turbo conversion my friends. it seems like its gonna b alotta stress, but i was gonna go boost eventualli. will most probably do its with hyperdrive as they have never made fun of me whenever i go into there workshop in my NA. anyone haf any experience with then?? will keep u all posted on how the work goes.
https://www.sau.com.au/forums/topic/53140-rb25de-pricing/#findComment-1044453
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
