Let's have a conversation in Japanese! (Romaji only)
  • Replies 105
Hey Justin,
Are you studying Japanese at the moment? Did you live there? Dont you think its a strange feeling speaking in Japanese to other gaijin when they already speak perfect English?
ha ha true but good for practice! Anyway sometimes my nihojin friends get a little tired...ha ha try speaking to! so at least with other gaijin we are on the same level...
wakarimashita ka
Ohayo Kuraigu desu, hajimemashita... watashi mo skyrine daisuki desu yo!
Engineer no nani desu ka? (think that's slightly off, supposed to be "what kind of engineer?"
watashi wa computer engineer desu.
should be "Engineer wa nani desu ka" i think no is wrong particle....
Well, no is 'ownership, as in 'brisbane in queensland' is 'queensland no brisbane', and is apparently useable for 'sub-thingies', like different areas of engineering... but... I could be wrong. It's been a while since I opened my jap books. :D
I think you've said "what is (an) engineer?" :D
Ah, so desu... Computer engineer! Anata wa joozu desu yo!
Ashiya no tenki wa dou desu ka? shidonee wa totemo atakai yo. ii tenki desu ne.
Ashiya no tenki ha kumori yo... chotto samui kedo daijyoubu.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
