Spotted a Gold ARX on Pennant Hills road around 12.30 today. It turned right at Pennant Hills. I think it was probably Danny.
Tooted and waved but he was in the right turn lane and I was in the curb lane.
Cheers
Andy
Spotted s1 green driving from brunswick juction to perth . And yes dale it was your car straight and driving again . All is looking good and be looking at getting it registered again very soon . Great drive couple of little issues but will be sorted .
spotted a white (S2 i think) right outside the carwash on corner of Springvale Rd and wells last night :(
flashed my lights
think they spotted me too :)
i wanted to say that this was me but i cant remember lol, i have seen you round once or twice though. Did you happen to get your car from SSV, they had a black one a while back i went to have a look at to suss out piping for my FMIC. its a terrific looking car mate :D
i wanted to say that this was me but i cant remember lol, i have seen you round once or twice though. Did you happen to get your car from SSV, they had a black one a while back i went to have a look at to suss out piping for my FMIC. its a terrific looking car mate :)
thats exactly where i got it from :cool: i kept seeing it there when i drove past every now and then. and i'm like... if its there next time i go past.. im gonna test drive it... and then once i did that of COURSE i had to buy it :)
i'll PM u i think i remember the plate :P
i used to always see a silver RS4 in the same spot aswell (before i had mine) and id have drool on the dash by the time it had gone :wave:
spotted a white (S2 i think) right outside the carwash on corner of Springvale Rd and wells last night :D
flashed my lights
Probably us but we didn't see you dude. :D
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
