Poor 32. Lucky it broke down where we were. Otherwise I think we could have been in the shit :P
Thanks HEAPS to Melv for coming and rescuing us! :hugs:
And thanks HEAPS to Mick for following us home to make sure that we made it :(
hahahahahaha yeah melv had just a little prob finding us lol
Ah I Can See You Just Can't Get To You lmao :looney: round & round we go that place was a maze :spcartman
no probs erin any time :angel: I know any of the gys would do the same for me :grouphug:
just a quick update.. turns out to be loose wiring, so thats easy fix.. now just need to wait for ecu tuning. :P
oh and honda city is cool! bring on the city turbo I say! :D
hahahaha there is a soft top turbo up the coast for sale 85 modle for 6k :looney:
that would be cool but thats just a crazy price :bonk: little 1000 lt rocks :(
I know why my car is so fuely ... Well, even more fuely and gutless than normal :(
Alternator is shagged. 12v maximum during running, and 11.buggerall volts once you turn lights on.
If you just turn the lights on, the voltage drops from 12.buggerall to 10.something fairly quickly... Is that a battery problem? Or is the battery only partially charged cause the alternator isnt doing anything? Even with revs (2500-3000rpm) it wont charge the battery at all, just holds a constant 12.3'ish volts.
Piece of crap. I'm with will :P Gimme the little buzzbox back :D
Glad to hear it's only something small Will.
I might ring Gav and ask him why he didn't answer my phone call at 11pm last night.
LoL, other than the sleep thing and all :(
Good to hear it was only a loose wire tho. I think, does that mean your not stripping it anymore? :P
if the alternator belt isn't slipping or overtightening, and measured idle voltage at alternator/battery not showing 13+ volts then alternator is gooooooonnnnnnneeeeeee. :(
dave you can still strip my ful sik subwoofa tape deck?! :(
hmm so does that mean next time I got pick up my pos 32 it'll sport a sohc head with a ded commie battery and sits on bricks? :D:( godamn bogans! :P
RB26ETT for Willis :D
Who needs to D(ouble overhead cams)?
Hmm... RB26 head on RB30 block....
Oh well, I'm sorta glad there is something fairly big wrong in a way... It makes a good excuse for the lousy performance and huge amounts of fuel smoke :D "Oh yeah mate, normally I got 800hp but damn alternator was shagged so I only had 100hp" :P
Now I'm not a mechanic... (Unlike some :S ) But I'm gunna disagree on this one...
Cause... The spark doesn't burn the fuel... The spark starts the fuel burning (I thought) and then the flame front ignites the rest of the charge...
So, tiny spark may not be perfect, but it will either ignite, or miss... Not just burn some of the fuel and spit the rest out...
Also, with low voltage, the injectors wouldn't be opening up as much anyway, so there would be less fuel than usual... (depending on ECU (the car does have EFI doesn't it Andrew :cheers:))
I'm guessing timing and / or fuel pressure and / or tune...
/awaits proof of my stupidity...
Dunno the technical side of it, but with Brutis2, when the alternator died and started giving low voltage he would run REAL fuely.
Then as the voltage dropped lower, he would misfire. Finally, car died totally.
Either way, the alternator is shagged. 12.2v at big rpm in neutral with no lights etc on isnt right. And 11.7v with the lights on also isnt right :cheers:
firstly strutto...low voltage can do weird things to the way a computer runs.
secondly a injector doesnt need to have a full 14.4 volts to operate properly
thirdly poor spark and overfueling ......well the fuel just extinguiishes the flame....cause the.....well it just does , hence the misfiring and such.
fourthly i think andrew will find that if he turn all accessories off the car will run better(cause of the low volt deal)
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
