  • Replies 56
Ok - have decided on a central location cause we all live miles appart. Not a big night but for those wanting to catch up and have a couple of drinks and start boasting some rediculous predicted lap times *cough* 1.25 *cough* then come to:
HolliAva - 36 Swan St, Richmond (opp station). I'd say maybe from about 8ish?
I will have to travel further than anyone (except for Emre) so no complaining about the location. Catch those that come there!
Deal... If it's only a few drinks this will be great.
Although I have another suggestion. Sandown is only 15mins drive from our area and there are a few "Wang crew members out this way" Me, Adz, Dee, Bec, Scott, Ferni just to name a few. If we wanted to have a few drinks their would be plenty of room to put people up. Then the track is only a short drive in the morning.
Mate - maybe we can All go to Holliava for a few early drinks - then the southo's can venture south to our area to kick on and the northo's can verture up to geoff to once again try try try to get Roy's car ready.... and kick on.
Geoff just bring the wife along.. unfortunately you'll have to put up with the likes of some girls such as myself this time.. I'll happily keep her company :)
Besides if you're all anything like Roy.. I can only understand half of everything he's saying generally (even when sober..) :) "cams engine modify this, exhaust that, blah blah cars rooted again, cars in the shop, cars not workin" :)
See you all on Sat @ 8ish
Better make an appearance then...........Roy and I are both car lovin' mechanical engineers Kaz and we love talkin code. Nelly has cracked the code though, it all means spending ludicrous amounts of money.
Ill be down, just convinced the client to do the shutdown during the week and not the weekend, convinced them they would save thousands in labour:thumbsup:
Not to mention i now get all saturday to work on the car...oh Geoff:)
Enough of this bashing Troy, hes all right, bit of a girl at times, but he is alright. He aint got nothing on Roy:)
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
